Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 06-06-2011, 06:28 AM
  #5356
Trader Rating: 14 (100%+)
(2) 6x10mm bearings for the rear-end of the chassis
(1) 8x12mm bearing for the inside of the diff
(1) 5x11mm for outside of diff
(4) 5x10 bearings for the front wheels
Thanks Kaybo!
Deznuts05 is offline
Old 06-06-2011, 08:00 AM
  #5357
k_bojar's Avatar
Trader Rating: 30 (100%+)
Thanks Kaybo!
that only works for the F104 with the aluminum/Pro diff parts...if you are running the plastic F103-styled diff pieces, you need and extra 8x12 bearing to replace the plastic bushing
k_bojar is offline
Old 06-07-2011, 05:09 AM
  #5358
mattwoodcraft's Avatar
Originally Posted by g12314
Here is a good starting point for Foam Carpet:
http://rcf1blog.blogspot.com/2011/03...tup-sheet.html
Jimmy
thanks for that i will give it a shot it certainly is different to what i am running now
mattwoodcraft is offline
Old 06-07-2011, 11:47 PM
  #5359
monkeyracing.cz's Avatar
F104X1 English version promo video ...
http://www.youtube.com/watch?v=wIABOiFTit0
monkeyracing.cz is offline
Old 06-08-2011, 12:15 AM
  #5360
how low gearing can you get on the F104?
said differently.. whats the gear ranges possible for a F104?
its needed for a high Kv motor.
MatsNorway is offline
Old 06-08-2011, 12:19 AM
  #5361
Pro10noob's Avatar
If you use the 0.4 module you can for certain go as low as 20/104.
These are the spurs and pinion i have here.
What are you planning??
A dragster??
regards Roy
Pro10noob is offline
Old 06-08-2011, 12:42 AM
  #5362
Nono no dragster.. it isn`t for me.
A friend is perhaps going to push the F104 a bit. going down in motor size and weight and down in turns to offset it..
a possible option is the team powers mini 540. it weights in a 140grams. supposedly..
Another option is smaller 2cell pack or 1cell and even lower turns.
Carpet and foam mostly..
do you need more gearing on 1cell?
another option i told him is to go with a Novak three80 motor. 100gramish and 200watts is as far as that type goes. But it would need for a custom motor mount.
hes currently running a 17.5 turn. (speedpassion i believe(heavy pig)) and is mostly running on a small track good for 1/12scale and m-chassie.
Old 06-08-2011, 04:57 AM
  #5363
i want one cant wait for the release date it will certainly be on my hit list.
Old 06-08-2011, 10:20 AM
  #5364
British Menace's Avatar
I just had an Email from Tamiya US. Saying it will be at least 3 months until the release of the X1 ..... Although!! The email also said the car would come WITh rubber tires and wheels, no body and "uncertain" about the motor!
A little different to the caption in the X1 promo vid saying none of these items would come in the X1 "Limited Edition" kit?!
British Menace is offline
Old 06-08-2011, 10:22 AM
  #5365
Also ..... I see Tower has the X1 listed at $274 ..............
If thats with no body.... no wings, No wheels and tires and no motor. It sounds like its going to be a little pricey to get this cool cat on the road
Old 06-08-2011, 01:32 PM
  #5366
robk's Avatar
Trader Rating: 22 (100%+)
Japan release is supposed to be July.
robk is offline
Old 06-08-2011, 01:50 PM
  #5367
NiMo's Avatar
July 16th
http://www.tamiya.com/japan/products...04x1/index.htm
NiMo is offline
Old 06-08-2011, 05:44 PM
  #5368
daign's Avatar
Pirelli Tires Test Vehicle F104
Real:
daign is offline
Old 06-08-2011, 06:45 PM
  #5369
A shame they are foam....... they are foam tires aren't they?
Eye sight isn't what it used to be hahaha
Old 06-08-2011, 07:36 PM
  #5370
Luosi's Avatar
Which would you guys recommend for a car on asphalt? Waiting for the X1 or a Black special with rubber tyres?
Luosi is offline
