Tamiya F104 Pro!
#5341
http://www.bocabearings.com/productd...ctSubGroupID=4
Boca bearing kits list the bearings , use, and thier sizes for each car.
#5342
Sorry I can't answer your first question, but as far as glueing goes I use contact cement for glueing counter tops. Just brush a coat of it onto the wheel, and a coat on the inside of the foam and let them dry for about 15 minutes. Then dunk both in some laquer thinner and they'll slide right together. Use some paper towel and laquer thinner to clean off any of the glue that gets on the side walls.
Its actually a pretty easy task once you do it a few times.
#5346
what is the softest out of the tamiya a and b foams? thanks
#5348
i have kawada 40s on the front and a's on the back and the car looses to much speed when turning(sounds strange i no
#5349
As in it pushes the front of the car to the outside of the corner?
Or slides completely to the ouside?
I find the GP-Speed tires ok.
I use 30 rear and 45 front or 25 rear and 40 front.
If i got a very high grip track i use 36 at the rear and 40 at the front.
regards Roy
regards Roy
#5350
it turns in ok but the back tends to push out and speed is scrubbed out to quick. i like the rubber tires and the way they flow.foams seem to be very direct
#5352
i have not had a lot experience with foam tire's on the carpet i got a set of tamiya set a and b will be running on carpet for the first time with it, i got the 1.3mm t-bar in it the f1 at the moment should i just go out with the asphalt set up? or if so what changes might need doing, not a lot time for any practice just turn and race the event
thanks
thanks
#5353
Well for carpet foam would be the best choice but if you have to run rubber start with A at the rear,B at the front,really soft setup for the rear,zero camber and hard front springs.
You can sauce the tires if allowed.
Rear complete and for starters none front.
If this goes well keep to it.
If you still have to much bite at the front,try CA glue to the side walls at the front.
Good luck.
regards Roy
Good luck.
regards Roy
thanks
thanks
#5355
thanks
thanks
http://rcf1blog.blogspot.com/2011/03...tup-sheet.html
Jimmy
