Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree12Likes
Tamiya F104 Pro!
Old 05-01-2011, 07:01 PM
  #5086
The Big Wig's Avatar
Tadaaa:
http://tamiyablog.com/
The Big Wig is offline
Old 05-01-2011, 08:02 PM
  #5087
Hi,
I want to build up a McLaren kit and for the moment just run it with the stock motor. I understand space is limited under the shell and was wondering what size ESC would fit. There are no dimensions in the manual like there are for the servo.
Any suggestions for a bargain basement small ESC?
fritzzz is offline
Old 05-01-2011, 10:24 PM
  #5088
hanzo3's Avatar
Trader Rating: 55 (100%+)
I just asked this and people been saying Cirtix w/ 21.5
hanzo3 is offline
Old 05-02-2011, 01:50 AM
  #5089
squarehead's Avatar
Trader Rating: 75 (100%+)
Thumbs up
I own 2 of them for VTA and USGT, and for the price and footprint, you can't beat them. I'll be putting another one in my F104, too.
squarehead is offline
Old 05-02-2011, 03:02 AM
  #5090
I am assuming 21.5 is the motor turns in your post above. If so, is this the ESC you mean?
Cirtix Stock Club Race ESC
http://www.speedpassion.net/en/produ...?p=12280&c=ESC
Would this work with the stock can and is it too big to fit in the car?
'cause if not then perhaps I should just buy one of these combos
http://www.amainhobbies.com/product_...tor-Combo-135T
I guess I was thinking more along the lines of something like this
http://www.amainhobbies.com/product_...se-Brushed-ESC
Sorry for all the questions but just want to get it right. Thanks.
fritzzz is offline
Old 05-02-2011, 06:15 AM
  #5091
mattwoodcraft's Avatar
the speed pasion from amain seems very good value for money
i think i will buy one my self to, im running a lrp quantum3 with theh tamiya sports tuned
mattwoodcraft is offline
Old 05-02-2011, 12:00 PM
  #5092
macavant's Avatar
Trader Rating: 65 (100%+)
Originally Posted by gsxr0311
Nice! when did you run it at norcal? are you going to race it?
The 1st time out was about a week ago (@nor.cal) and it was having issues with oversteer, built to kit instructions. It would go from slight understeer to snap oversteer, right past the apex of majority of the turns. Since then - I have taken some of the tips from this thread to adjust the car. I have installed a red spring for the damper with lighter damper oil, lower rear ride height, and applied tire compound on the insides of the front foams. The rears are now planted with some understeer. The car could also use a bit more speed @ back the back straight. Overall - (to me) it's easier to drive than my F103 and steers / reacts better than my F201. IMO it flows a bit better than both 103, 201. Ran the car yesterday after the on-road races were done. It's a fun car to drive.
Quick clip with my nephew operating the camera: http://www.youtube.com/watch?v=U8z9GPalzXs
macavant is offline
Old 05-02-2011, 02:55 PM
  #5093
Oortael's Avatar
I use the Speed Passion cirtix club race with a GM 13.5T motor. It fits very well and keeps cool. I've run a 93 spur with an 27 pinion.
Oortael is offline
Old 05-02-2011, 06:24 PM
  #5094
Originally Posted by The Big Wig
Hmmm. What's new here.
-F104X1 Chassis and upper deck are glassfibre so we'll have to wait for a carbon upper deck.
-Motor mount bridge/center shock mount is aluminium.
-TB-03 motorspacer? I've tryed that but it's impossible to mount a mabuchi without taking the pod apart.
-Heavy rear left wheel mount?
-Strange bulky left side spacer between pod and wheel mount?
Old 05-02-2011, 07:35 PM
  #5095
squarehead's Avatar
Thumbs up
The best part is no damper plates—instead using a side shock or swizzle stick like the early Trinity Revolvers 1/12th scale cars and many link cars today.
I'm hoping for those parts to be available as a kit to upgrade a standard F104 to damper tube setup.
Old 05-03-2011, 07:39 AM
  #5096
Redwings's Avatar
Default BLACK CAN MOTORS
Hey guy,
Here is Canada at the TCS races we have stopped using black can motors in the F1 series. Too many guys have been blowing them up even with the proper gearing ratio in a 5 min. race. Some of them even blew 3 brand new ones in a single race. I still have ones from the TCS finals 3,4 even 5 years ago and not a single problem.
Any of you guys experience any or the same problem?
Paul
Redwings is offline
Old 05-03-2011, 09:32 AM
  #5097
http://www.ustream.tv/recorded/14428650b
On the spacer: jong jing blabla jin moto blabla jadajada "bearing"..? Could it be some sort of better wheel support? Who understands Japanese?
..blabla "counterweight"..
They seem to move as much weight possible to the left side (motor spacer, wheel hub, axle spacer).
Old 05-05-2011, 07:15 AM
  #5098
RHH
Default Camber Caster plate
I tried Mantis Works camber caster plate last weekend and it is extremely effective. It stabilizes the car, no twitchiness and smooth turn in and corner exits. I run a 10.5 brushless with 5200 batterys and the part is a cure for so many of the hard to tune out negative characteristics of the 104.
It is a revolution IMO.
Ron
RHH is offline
Old 05-05-2011, 09:34 PM
  #5099
HeliYogi's Avatar
Trader Rating: 17 (100%+)
Default More X1
Hey Barry, a picture is worth a thousand words (OMG but there still in Japanese )
Oh well,
Cheers, Marcos
HeliYogi is offline
Old 05-05-2011, 09:37 PM
  #5100
Arahawak's Avatar
Trader Rating: 32 (100%+)
Looks interesting.. Counter balancing weight sort of..
Hope it sells in part rather than getting the whole kit...
Any idea when is the release date?
Arahawak is offline
