Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 02-20-2011, 08:52 AM
  #4606
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by HeliYogi
I don't understand what is up with the release of tree more F104W kits:
- Ferrari 643
http://www.tamiya.com/japan/products...i643/index.htm
- Mclaren
http://www.tamiya.com/japan/products...aren/index.htm
- Mclarean
http://www.tamiya.com/japan/products...n_mp/index.htm
In Japan, Tamiya has a separate TCS class for the W's but is there option tires and TCS parts? I Have not seen them? Were is this leading up too?
Sell the F104?
Bring the F103 out of the box and mix it up with the F104?
Get a F104W and mix up using F103 tires?
I ran the race before last at TQ (F1 winter series) close to 15 or more cars. Only two F104Pro (me and Mark), the rest went back to the F103.
Anyone has info on this mystery?
Cheers, Marcos
All 3 cars state that they come with foam tires...Not sure what that means for TCS. If they brought back the old A's and B's, it would be game on.
robk is offline
Old 02-20-2011, 09:41 AM
  #4607
Trader Rating: 61 (94%+)
Any one need 104 foams i got two full sets new. im needing a set of ride 104 wheels.
tcb22185 is offline
Old 02-20-2011, 06:05 PM
  #4608
gsxr0311's Avatar
Trader Rating: 19 (100%+)
Originally Posted by BP SHADOW
Yes I do, I can ship them to you for $50
PM me if you want them
pm sent. thanks
gsxr0311 is offline
Old 02-20-2011, 06:08 PM
  #4609
gsxr0311's Avatar
has anybody tried the rp f104 rubber tires? i know this company did well with touring car tires, but im not sure on f1's.
gsxr0311 is offline
Old 02-20-2011, 06:16 PM
  #4610
can you post a link?
tcb22185 is offline
Old 02-20-2011, 10:55 PM
  #4611
Scooby Horton1's Avatar
Originally Posted by MikeR
Hi,
They have different shock mount designed for the respective motor pods. The EXO103 also has wider body mount locations for F103 bodies and includes extra alloy posts needed for the top plate that the F104 already supplies.
EXO103/104 wheel bases are the same.
Thanks,
Mike
Hey Mike can you post some setups that you use on carpet with your 104 kit?
Scooby Horton1 is offline
Old 02-21-2011, 01:26 AM
  #4612
kneedeeppow's Avatar
Originally Posted by Abu Salahuddin
The new upper deck will help the chassis to have a little bit of flex. This will aid in you having an improve traction. More suitable for low grip asphalt on rubber.
anyone got a part number for this upper deck? is it like the f60 one?
kneedeeppow is offline
Old 02-21-2011, 03:23 AM
  #4613
Taman's Avatar
Trader Rating: 67 (100%+)
54278 F104 Separate - Type Upper Deck Set
Usable with :
F104, F104W Chassis
This carbon fiber upper deck is split into front and rear sections, thereby allowing the chassis to become more flexible.
$24USD from Stellamodels
Taman is offline
Old 02-21-2011, 04:47 AM
  #4614
sounds like i might need to get one for my pro car. any one notice how hard it is to set the diff with ride wheels? like the inside is off or some thng.
tcb22185 is offline
Old 02-21-2011, 04:48 AM
  #4615
also robk how are you using a diff user with the exotek pod?
tcb22185 is offline
Old 02-21-2011, 09:22 AM
  #4616
MikeR's Avatar
Trader Rating: 15 (100%+)
I have not run carpet much so don't have anything worth posting but one of the Socal fast guys was kind enough to post his set up for high grip carpet with rubber tires here
http://www.rctech.net/forum/8682908-post2374.html
MikeR is offline
Old 02-21-2011, 10:03 AM
  #4617
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Usable with :
F104, F104W Chassis
with $18 shipping to US.
F N CUDA is offline
Old 02-21-2011, 11:34 AM
  #4618
Default F104 Pro from The Netherlands
Hello ,
So, This is my lookalike version of the F104 Pro from Inzane
( Thanks InZane )
Regards
Jack Akkerman
The Netherlands
Attached Thumbnails Tamiya F104 Pro!-kl1.jpg   Tamiya F104 Pro!-kl4.jpg   Tamiya F104 Pro!-kl6.jpg   Tamiya F104 Pro!-kl7.jpg   Tamiya F104 Pro!-kl3.jpg
Jackleg is offline
Old 02-21-2011, 12:06 PM
  #4619
gsxr0311's Avatar
here is the link to thr rp's
http://www.rcmart.com/catalog/rc-tir...h=595_744_1390
gsxr0311 is offline
Old 02-21-2011, 01:29 PM
  #4620
robk's Avatar
Sandwich the lexan between the motor plates and the lower pod plate. All set.
robk is offline
