Tamiya F104 Pro!
#31
I’m not sure if any of you have seen this or not. I did a search on the net for the F104 Pro and found these. It looks like Tamiya is going to show some extra bits for the new F1 kit at the upcoming Shizuoka Hobby Show next week
http://tamiyablog.com/2009/04/tamiya...show-2009.html
51377 F104 Body Parts Set
54157 F104 Titanium Screw Set
54158 F104 Aluminum Diff Housing Set
54163 F104 Carbon Lower Deck
54164 F104 Carbon Upper Deck
54166 F104 Aluminum Motor Mount (Left & Right)
54169 F104 Aluminum Pivot Post
54178 F104 Formula-Tuned Motor (32T)
#33
What do you guys think about this battery down the center ? I was talking to someone at the track the other day and his opinion is that it's a bad idea... according to him, this will transfer less weight side to side an therefore less grip in the turns... Is there any truth to this ?
#34
Are most of you guys TCS minded when it comes to these things? If there was a TCS race around here I would build a car for it. But without it I would rather go with an MLP car.
It seems like The Tamiya cars stay TCS legal as long as theres the hope of a race near by. As soon as Tamiya discontinues a car (which means no more TCS for that chassis) then 3Racing sells a bunch of hop ups for it.
#35
Weight down the centerline should be better. Just look at open wheeled race cars - from Formula Fords to F1 and Indy Car - most of their weight is concentrated down the center of the car.
#39
#41
Well as someone else also mentioned the Cross car could run the battery in that configuration and the guy running one locally here ran quite well like that. Also there are a few 1/12th scale cars that run 4 cells in-line that run pretty good as well. It's all just a matter of getting the right setup for the configuration you have.
#42
Looking to get my first F1 car and after reading this thread I dont know whether I should get the Tamiya F104 or the new HPI car. Is there any any threads on this forum talking about the new HPI car?
#43
And what is the model name of the HPI F1? I am trying to find it.
#45
The F103 kit price through our L.H.S. is $149.99. I believe our cost on the new F104 to be around $200.00, through our L.H.S. We are currently running the F103 TCS spec. class, and the car is awesome. There is no comparison to the F103 and the HPI car. We run on a large permanent outdoor asphalt track. The F104 looks to be a major improvement and more refined, for more serious F1 racing. The Tamiya F103 kit makes for an easy competitive spec class of racing. The new F104 looks to be a natural progression for our club. We run the car basically box stock with the kit foams, which work by far the best, on our high bite track. I wish my 13.5 TC was as inexpensive to race.
Just simply observation....15th R version is about $220 USD...this one, hope they will throw in the alum heat sink motor mount...with almost the same upgrade like the 103R, with the revised body, revised tire set...I would guess it will be around $300 USD. And I think that is reasonable. But not higher...
Race tuned 12th scale is around $250 without tires and body.
