Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 01-23-2011, 01:12 PM
  #4306
gashuffer's Avatar
Trader Rating: 48 (100%+)
Originally Posted by robk
The biggest problem is the Tamiya rubber tires pick up all the carpet fuzz and crap, and then the tires loose traction. It seems like this gets better if you use tires that have been run on asphalt, but it never seems to go away 100%. Some tracks are worse than others as well.
Which rubber tires work best then? Non TCS
gashuffer is offline
Old 01-23-2011, 01:27 PM
  #4307
Last friday i bought myself a F104 PRO and built it in a rush.
Today it was the first time i drove the car and inmediately the car felt great and super fast.
I even won the first race (after i also took the pole position) of the belgian tamiyacup today, never had to use any additive on the tires for more grip.
Just one option installed on the car (the high traction T-bar) and that's it and the car runs great.
This was one of my most positive expierences with a new car.
It was allmost 2 years ago i drove for the last time my F103 full option and the F104 PRO runs smoother and more relaxed.
Absolutely a top car, if i may say so.
addicted2blue is offline
Old 01-23-2011, 01:47 PM
  #4308
rc_square24's Avatar
Quick note if anyone has an F104 for sale and will ship to Canada please PM. Buddy of mine is looking to spend $150 plus shipping.
Thanks!
rc_square24 is offline
Old 01-23-2011, 06:26 PM
  #4309
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
congratulations on the win!
Tommi Makkinen is offline
Old 01-23-2011, 08:50 PM
  #4310
adriano87dj's Avatar
Trader Rating: 43 (100%+)
hey all,
question regarding the front wheel spacers
ive lost mine
Replacements? Cant seem to find any on ebay or even on google searches....... great support there tamiya thanks!
who else does a 5x0.5mm spacer?
adriano87dj is offline
Old 01-23-2011, 09:14 PM
  #4311
robk's Avatar
Trader Rating: 22 (100%+)
I guess. I've only tried Tamiya tires.
The first couple TCS races last year were to have rubber tire on carpet, but they all wound up being foam races.
robk is offline
Old 01-23-2011, 09:17 PM
  #4312
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Thanks!
Youve got PM
BP SHADOW is offline
Old 01-23-2011, 09:43 PM
  #4313
F N CUDA's Avatar
Trader Rating: 34 (100%+)
For carpet right?
I know that the Pit Shimizu tires are the tire of choice at TQ Raceway for the F104 but I honestly forgot which ones are the correct ones.
There are 2 soft rear compounds and I don't know which is best and I can't remember what I even have for my F104 when it comes to the fronts, whether they are hard or medium.
Hopefully someone that also runs there will chime in with part numbers for the hot combo.
F N CUDA is offline
Old 01-23-2011, 11:29 PM
  #4314
lightfoot's Avatar
The best 104 rubber on carpet combination for me is:
Pit Shimizu PS-0575 REAR ( soft compound )
Pit Shimizu PS-0577 FRONT ( 3 compound )
TAMIYA 51378 F104 SPARE WHEEL SET
use the Tamiya foam insert for the rear instead of the stock insert if you have too much rear traction...
use the stock insert if you need more rear traction...
TQ is the only place in the Americas who carries these tires...
http://www.tqrcracing.com/shop/produ...&s_maker_id=49
lightfoot is offline
Old 01-23-2011, 11:47 PM
  #4315
F N CUDA's Avatar
I knew you'd come thru Charles.
I couldn't remember the numbers and I even knew where to look.
I know that Sean (TQ Racing) had ordered the second type of Shimizu soft rear compound but haven't heard if anyone has compared them to the soft tires that we all have been running.
Any word on these?
Supposed to actually be marked for carpet and low bite asphalt.
F N CUDA is offline
Old 01-24-2011, 12:38 AM
  #4316
kneedeeppow's Avatar
am looking for replacement diff balls. what size does the 104 take? would these work?
http://www.rcmart.com/catalog/rc-trf...l-p-32021.html
cheers
kneedeeppow is offline
Old 01-24-2011, 01:36 AM
  #4317
Thx
Old 01-24-2011, 02:11 AM
  #4318
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
cheers
They're 3mm. Those ones look to the wrong size. I grabbed some 3mm ceramic ones and it's been good as gold.
PDR is offline
Old 01-24-2011, 02:59 AM
  #4319
Originally Posted by adriano87dj
hey all,
ive lost mine
you can try maybe some wheel shims for tamiya touring cars. those little color-coded washers might be of some help for you.
hope it helps
Old 01-24-2011, 03:39 AM
  #4320
InZane's Avatar
hey all,
ive lost mine
XPress M5 Collars>>
InZane is offline
