Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree14Likes
Tamiya F104 Pro!
Old 12-27-2010, 09:08 AM
  #4156
ghoppa's Avatar
Trader Rating: 63 (98%+)
Default li-po problem
Hey Guys, F104 Black is almost ready, but I have a problem with making my battery fit.
I just purchased an Orion 4000 maH but I believe its too long for p/n D3 (page 13 in the manual) to work properly, any suggestions on how I can keep the battery secure in case any of you have encountered the same situation..
any help will be appreciated!!!
the battery:
http://www.teamorion.com/orion/produ...4103noPlug.jpg
ghoppa is offline
Old 12-27-2010, 09:26 AM
  #4157
rc_square24's Avatar
The fitment of the plastic clip/holder depends on the battery even if its stick pack shaped.
For mine I had to file and heat it to bend the tabs back a bit to fit my battery.
rc_square24 is offline
Old 12-27-2010, 12:13 PM
  #4158
2-Bad's Avatar
Trader Rating: 24 (100%+)
the battery:
I've got an Intellect 4200mah Stick in mine. had to dremel ridges off on the battery hold-down clip, but thats about it....
Post # 4040
2-Bad is offline
Old 12-27-2010, 04:46 PM
  #4159
j.d.roost's Avatar
Trader Rating: 32 (100%+)
Originally Posted by gashuffer
If I can run a spool on carpet I would. Some of the guys I race with ask me why is my diff is so tight
I think the cats out of the bag now
I too run a 103 my 104 sits on the shelf.
Yea,T.
It was an "aha" moment last weekend for sure.
j.d.roost is offline
Old 12-27-2010, 06:01 PM
  #4160
robk's Avatar
Trader Rating: 22 (100%+)
I put some carpet setup stuff here:
http://rcf1blog.blogspot.com/
Compare and contrast i'm probably all wrong about this
robk is offline
Old 12-27-2010, 06:22 PM
  #4161
BP SHADOW's Avatar
Hey Rob, is the Illinois TCS race gonna be foam or rubber?
Is it a 1 or 2 day event?
It might help if someone from the host track got on one of these threads and laid down the 411
BP SHADOW is offline
Old 12-27-2010, 06:38 PM
  #4162
robk's Avatar
Looking at the rules, I think both classes may be raced, like 103 and 104 last year...Eric from the track has told me it WILL be a 2 day race, as well.
robk is offline
Old 12-27-2010, 06:47 PM
  #4163
Arahawak's Avatar
the battery:
I didn't bother with the plactic part, I just use velcro to strap the battery to the upper deck. No issues so far..
I try to post a picture tonight for those who needs visual aids..
Coz I do..
Arahawak is offline
Old 12-27-2010, 06:54 PM
  #4164
Arahawak's Avatar
Double post
Arahawak is offline
Old 12-27-2010, 06:57 PM
  #4165
smracer31's Avatar
What size bearings are needed the f103 front wheels?
smracer31 is offline
Old 12-27-2010, 07:27 PM
  #4166
robk's Avatar
5x8
robk is offline
Old 12-27-2010, 07:38 PM
  #4167
gsxr0311's Avatar
Trader Rating: 19 (100%+)
any news on you guys with the exotek chassis, how are they working for you? any race results?
gsxr0311 is offline
Old 12-28-2010, 12:24 AM
  #4168
Check with Fernando.
Sydewynder is offline
Old 12-28-2010, 11:56 AM
  #4169
Oortael's Avatar
Hey Guys,
Thanks for the advices on my diff. It works now fine. You've helped me a lot. What I've done is:
1. Sanded the diff. plates with 600 grit sandpaper.
2. Put the very less "kit grease" in the holes of the spur (not on the plates)
3. Press the steel diff balls in
4. Changed the thrust washers
I raise my glass to you.
Cheers!
Oortael is offline
Old 12-28-2010, 12:50 PM
  #4170
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
Originally Posted by MikeR
Rubbing the rim?? Post a pic. Are you Talking about the pin?
Turns out to be the Ride rims, the stock Tamiya rims dont rub
abailey21 is offline
