Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 12-13-2010, 09:45 PM
  #4006
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by rc_square24
Does anyone make a servo mount set that has threaded holes where the lower and upper decks screw together? Tamiyas aluminum servo mount is a thru hole design like the kit part, while their alum rear pivot mount changed to a threaded thru hole so you replace the top nut and single long screw with top and bottom screws.
The reason I want it is because it's difficult to tighten the ball studs /nuts while holding the chassis flat, the screw just spins around. Of course I can hold a driver/wrench on the other side but wouldn't this prevent the chassis from being tightened evenly and flat? Like how you wont tighten a TC top deck by holding the chassis on your hand? Or does this not matter on the f104?
I'll have some around January. The design will work with 103 and 104.
MikeR is offline
Old 12-13-2010, 10:36 PM
  #4007
Is there a metal rear spur gear available? I stripped the stock plastic one.
total3d is offline
Old 12-13-2010, 10:44 PM
  #4008
Foxxrocket's Avatar
Spur gear are plastic, so that when something happens it takes the brunt of it. If you use a metal spur gear, the damage will just go somewhere else.
Foxxrocket is offline
Old 12-13-2010, 10:47 PM
  #4009
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
none that I can recall bro.
youre best bet is to just make sure you get the mesh correct and really tighten the motor screws... metal spur gears and pinion gears only seem to work on nitro cars...
Tommi Makkinen is offline
Old 12-13-2010, 11:48 PM
  #4010
The stock plastic ones can be very durable...just make sure you mesh them right.
InspGadgt is offline
Old 12-14-2010, 12:27 AM
  #4011
Yeah i had it meshed pretty well, but the rear axle carrier popped out, and the rest is history. Was hoping there would of been a nice alloy one.
total3d is offline
Old 12-14-2010, 03:37 AM
  #4012
Oortael's Avatar
Has anyone tried CS-Ultra High Grip for foam tires?
Oortael is offline
Old 12-14-2010, 06:30 AM
  #4013
Arahawak's Avatar
Trader Rating: 32 (100%+)
I don't remember nitro car has metal spurs...
Arahawak is offline
Old 12-14-2010, 07:31 AM
  #4014
Oortael's Avatar
Would you suggest using TRF415 spurs like 54055 or 51056?
Oortael is offline
Old 12-14-2010, 08:39 AM
  #4015
some older nitro cars have metal gears... i saw one in a collection of a friend of mine...
oh crap... now i realize im old!
Old 12-14-2010, 10:28 AM
  #4016
Very few nitros had metal spur gears...metal on metal for an external gear just does not work very well. The friction is migh higher and heavier. Internally in a gear box works fine because you can keep them well lubricated.
In this case if the rear axle carrier had come off and it was an aluminum gear it still would have been chewed up.
Old 12-14-2010, 12:35 PM
  #4017
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Does your F104 have a plastic right side pod motor mount, or the aluminum one ?
RedBullFiXX is offline
Old 12-14-2010, 01:53 PM
  #4018
2-Bad's Avatar
Trader Rating: 24 (100%+)
Depends which F104 version you buy. The frp has plastic, the black is alloy, etc...
2-Bad is offline
Old 12-14-2010, 02:26 PM
  #4019
Yes, and the plastic one will not hold the motor in place very well at all.
Could be the issue he is having with stripped spur gears ?
Old 12-14-2010, 02:59 PM
  #4020
Raman's Avatar
Trader Rating: 94 (100%+)
Im selling a almost brand new F104 Pro. Take a look here if you are interested in one.
http://www.rctech.net/forum/r-c-item...ort-8-5-a.html
Raman is offline
