Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree14Likes
Tamiya F104 Pro!
Old 12-07-2010, 01:25 PM
  #3946
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by Arahawak
any teaser or preview what we are getting??
www.mantisworx.com !!!
MantisWorx is offline
Old 12-07-2010, 02:21 PM
  #3947
I'm sure this has been asked and answered, but I'm considering the Tamiya F104/Exotek coversion (for my own wacky reasons). I'm not that familiar with the F104 front suspension, though I like the way it looks. Currently I have a 3R F109 (great car), and I like the ease with which the front camber and caster can be adjusted. Are both adjustable on the F104? If so, how difficult is it? Looking at pics of the car it doesn't appear that either are adjustable, but that seems hard to believe. Any help out there?
Bob Kelly is offline
Old 12-07-2010, 02:33 PM
  #3948
MantisWorx's Avatar
you cannot adust the castor at all and the camber adjustment is also limited to 1* BUT when you go to that setting it throws the castor(decreases it) off because it only moves the front mounting point of the arms. some have said that shimming the rear ball up can help but for the life of me i cant seem to get that to work on Autocad!! this is why i designed the Mantisworx camber kit, it adjust both setting and you can go with -1* or -2* and still have full castor adjustments without effecting the camber!
Old 12-07-2010, 02:34 PM
  #3949
There are aftermarket parts that allow you to adjust camber to pre-set camber amounts. But they are not as adjustable as the stock F1-09 front suspension.
The Tamiya adjusment block allows you to adjust camber in .5 degree increments up to 2.5 degrees.
The 3Racing adjusment block allows you to adjust camber in 1 degree increments up to 3 degrees.
While the Tamiya part has a finer adjustment the 3Racing one has an easier adjustment since you don't have to take apart as much of the suspension to do it.
InspGadgt is offline
Old 12-07-2010, 02:46 PM
  #3950
MantisWorx's Avatar
this is basically what you get with the Tamiya way of adjusting camber, the more camber you add the more your castor is decreased!
Old 12-07-2010, 02:56 PM
  #3951
robk's Avatar
Trader Rating: 22 (100%+)
You don't need auto cad. It's also not really increasing caster, it is causing a more radical dynamic caster effect. Raising the rear link causes the upper arm to move forward under compression, which actually takes away a bit of caster from that side. It does give added grip mid corner.
Add shims to the rear ball and then work the suspension. No need for computer models when you have a 3d model in your hand
robk is offline
Old 12-07-2010, 04:31 PM
  #3952
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
What kind of ride height are you running on carpet rubber?
The way the front end is set up (with ride tires and rims) I'm running 5.5mm in the front.
Also would you match in the rear, or run .5mm higher like i always ran in my TC
abailey21 is offline
Old 12-07-2010, 04:45 PM
  #3953
MantisWorx's Avatar
not saying that you are wrong, i just cant wrap my head around it! it seems to me that if you shim the rear (which you cant shim very much or it will eventually bind up) when the suspension is compressed it will make the arm go more towards the front of the car which is what you are trying to get away from right? maybe shimming the front is the way to go???? Either way my kit does away with all of that and you get straight castor/camber adjustments
Old 12-07-2010, 06:13 PM
  #3954
Shimming the rear pivot will cause caster to decrease as the suspension compresses. Shimming the front would do the opposite...so I would think to negate the caster effects of moving the front pivot in you would need to shim the front pivot up.
Old 12-07-2010, 06:47 PM
  #3955
Not sure if it would or not...Just commenting on the physical movement of the suspension.
Old 12-07-2010, 08:28 PM
  #3956
robk's Avatar
What I am talking about is the suspension design of the Associated, CRC, and most other 1/12 front ends.
The car loses caster as the suspension compresses. Since caster jacks weight back to the opposite corner, getting some of that weight back under compression (ex. mid corner) gives a bit more grip.
robk is offline
Old 12-07-2010, 08:38 PM
  #3957
And technically even having the upper arm level will decrease the caster as suspension compresses. The only way to have the caster remain static when only 1 of the 2 suspension arms moves is to have the arm perpendicular to the caster so that the arm's movement is in-line with the caster.
Old 12-07-2010, 08:51 PM
  #3958
robk's Avatar
The 104 does have a small amount of dynamic caster built in. I just try to increase it if there is enough rear traction for the car. I noticed the car would push mid corner quite a bit if the rear end was stable in most cases.
robk is offline
Old 12-08-2010, 12:08 AM
  #3959
Arahawak's Avatar
Trader Rating: 32 (100%+)
Erm I am not good with words description.. Do you have a picture as an example??
Arahawak is offline
Old 12-08-2010, 03:50 AM
  #3960
gashuffer's Avatar
Trader Rating: 48 (100%+)
Adding shims under the ball connector where the arms snap into on the topdeck will increase static castor. This will raise the rear of the arm by how many mm shims you use.
Please excuse my dirty car
gashuffer is offline
