Tamiya F104 Pro!
#3737
Screw in the shock shaft ball end(if there's enough thread to screw in more), or with plastic shims on the shock shaft inside the shock body.
Btw, did you add the 4mm worth of shims inside the shock and set to 60mm shock length as per Exotek instructions?
#3738
To reduce droop you need to shorten the center shock by screwing in the ballcup or adding spacers/orings inside the shock under the the piston.
Edit: sniped by Freakah lol
#3741
That kit has most of the hopups on it. The carbon chassis is stiffer than the FRP one found in kits.
With that being said, if I were to buy a car based on the 103 wheelbase and tire size I would get the TRG car. Outstanding design.
#3743
our track is running 17.5 turbo and it is awesome! im using a Team Powers 17.5 with an Tekin RS.
#3744
#3746
Hey Mike, We have the F1 running 21.5 on rubber tires doing 11.8 laps. how fast do we need to go. Ron H,
#3747
Here is another band of F1 tires. http://www.rctech.net/forum/rcmart-c...w-arrival.html
http://www.tqrcracing.com/shop/produ...&s_maker_id=49
#3750
The F104 upper arms that I put on my F109 are really tight on the pivot balls and was wondering what you guys were doing with the F104 about that. I have several runs on the car and still the front suspension is too tight.
