Tamiya F104 Pro!
#331
good !
#332
if thats the case, then why did AE and Losi have their buggies and trucks run on batteries in the same configuration as the F-104 and never had any "turn-in" issues? i'd say Tech Racing did their sums and believe this is the best solution. otherwise, they would not gamble their reputations on releasing a kit with such a perceived fatal flaw...
#333
I think a lot of the reason the batteries have been run down the middle is to make a more realistic representation of the newer 1:1 cars which are much narrower.
#335
Off road cars hang the motor off the back end of the chassis for stability, and the battery is centered to reduce the polar moment since car will experience a ton of disturbances which may not be symmetrical. This is not the case with an F1 car. The length to width ratios are also completely different.
i agree with you on that, but still... i say Tech Racing and Tamiya knew what they were doing when they came up with this design. otherwise, why release a kit which may have such potentially horrendous handling characteristics?
#337
Lol.
I'm going to wait and see how the real world results pan out, I'm going to eat my hat if they they have released an inferior design.
Mine should be halfway between HK and NZ at the moment.
#338
I like it with the sculpted side pods... That's one of the things that's drawing me to buy this.... But I'm still waiting to hear from more people about the handling...
#339
Copied from the tamiyaclub thread.
http://www.tamiyaclub.com/forum/inde...st=40&start=40
took mine for a spin on the weekend with a SuperStock RZ motor, good grief it is fast!!! Slippery at low speeds but corners like it is on rails when those wings are working at top speed, man it is fun.
#340
#341
What are the two screws for that are mounted in the lower front suspension for?
#342
When Fred Medel brought the chassis over to Tamiya America to show off a few weeks ago, he deduced that those two screws allow adjustment and control for "droop"; if you want to maintain a certain ride height in front, they can be both loosened and have shims installed under them to prevent them from bending. OTOH, given the car's inherent "push", I kinda want some weight transfer to the front when I lift or brake. For now, anyway.
#344
Does anyone know if the front and rear wings made for the F103 will fit the F104 as there is some nice aftermarket ones around
#345
