Tamiya F104 Pro!
#3256
This looks interesting - 1/10 R/C F104 PRO Black Special (Limited Edition)
Its going to be shown at the Hobby Show
http://www.tamiya.com/english/hobbyshow/10THS_index.htm
#3257
#3258
Hey guys,
I will be racing a F104 Pro indoors this winter and need some help. The surface is going to be un-prepared rubber floor (highschool gym floor) and I am not sure if I should use foam or rubber tires on this.
Also, what is the largest battery that will fit? I have some Turnigy 5200mah 2S batteries that I would like to use but I don't know if they will fit.
Please help.
Please help.
#3259
What Is the traction like on the rubber floor? High, meduim or low? Rubber tires will work on almost all surfaces, but at the cost of extra grip. Foam tires will give the car more grip and speed, but the surface has to be well prepared.
#3260
There will be no surface prep. And because it is a highschool, there will be whatever dust and dirt from the days activities on the floor.
#3261
#3262
#3263
#3265
Suspended
#3266
I think the first issue is your ride height. You have it set up with forward wedge.You want the car riding at least level, if not nose high. If you haven't done so, I would put a medium thickness lube on the kingpins to slow down the motion and weight transfer.
Next I would start dialing negative brake expo into it. Then I would start dialing brake out on your radio, if you still have the issue.
I have yet to have a braking problem with the 104, if anything, I could use more brakes, I have a feeling that my speedo might have an issue with the brakes.
Has anyone the opportunity to prove that? I only own silver cans for racing.
#3267
I'm going to wear this out:
#3268
I just received my F104 Pro kit, I'm just wondering if anyone can offer any suggestions on the build or whether there are any crucial hop-ups I might want to consider before I put it together?
#3270
A steel axle from the F60 kit(#3555152) can also help you get a handle on the car in loose conditions.
