Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree14Likes
Tamiya F104 Pro!
Old 05-14-2010, 07:48 PM
  #2701
rtypec's Avatar
Originally Posted by RedBullFiXX
While offset axles do shorten the wheelbase by 3.5mm, that is not the point of their use in tuning.
Offset axles locate the axle behind the kingpin to change the way a car turns, and have a profound effect on handling and added stability.
One can expect mid corner, to corner exit under-steer with this option.
Nuts...that sounds like something I need but keep forgetting to order I guess I'll just have to keep on pedaling it
rtypec is offline
Old 05-15-2010, 01:36 PM
  #2702
k_bojar's Avatar
Trader Rating: 30 (100%+)
Has anyone tried the HPI F10 tires on their F104s? do they mount on the Tamiya rims? Since i know HPI uses wheel hexes on the front/rear of the F10, I assume those rims are outta the question
thanks
k_bojar is offline
Old 05-16-2010, 04:32 AM
  #2703
cyclone x's Avatar
just got one what upgrades should i do to it
cyclone x is offline
Old 05-16-2010, 04:41 AM
  #2704
k_bojar's Avatar
if you read back a few pages you'll see this question asked (several times), chase
but...
rear motor mount and soft -tplate - everything else is eye candy
depending on what you are running at Mimi's - you got soft rear rubbers and hard front rubbers
k_bojar is offline
Old 05-16-2010, 04:52 AM
  #2705
cyclone x's Avatar
but...
ok thanks man
Old 05-16-2010, 06:31 AM
  #2706
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
any ETA on the Wolf WR1
R
UltegraSTI is offline
Old 05-16-2010, 06:38 AM
  #2707
j.d.roost's Avatar
Trader Rating: 32 (100%+)
Will the Wolf be ok to use at TCS races?
I ran my "107" yesterday (basically same car as the Wolf) and with the wider
width and the 103 tires the car was on rails.
Technically the release of this kit allows you to mix and match 104/103 parts.
j.d.roost is offline
Old 05-16-2010, 07:44 AM
  #2708
colt1402's Avatar
Trader Rating: 94 (100%+)
Have anyone tried using the 3racing f104 wing set? Any feedback compare with our stock wing?
colt1402 is offline
Old 05-16-2010, 08:00 AM
  #2709
k_bojar's Avatar
you bringing this out to Ray Murray's race at NJMP??
k_bojar is offline
Old 05-16-2010, 12:34 PM
  #2710
robk's Avatar
Trader Rating: 22 (100%+)
This becomes highly interesting for f104 rubber tire. I wonder how the Wolf tires are??
robk is offline
Old 05-16-2010, 12:42 PM
  #2711
j.d.roost's Avatar
I might have to work
If I can get off I will have it with me.
Old 05-16-2010, 12:44 PM
  #2712
j.d.roost's Avatar
By the looks of the rears they are the same as the Tyrell p34 tires.
No workie.
Old 05-16-2010, 02:07 PM
  #2713
aussierevo's Avatar
Trader Rating: 14 (100%+)
I've been using them for the past 6 weeks or so. Very flexible and can take a hit pretty well.
When I ran the car back to back changing the wings from the kit to the 3# racing, I felt the car handled better at the front and had better rear grip.
I do run rubber tires all round.
aussierevo is offline
Old 05-16-2010, 09:07 PM
  #2714
dildil's Avatar
hey guys, sadly, I'm selling my f104 night racer
if anyone is interested:
http://www.rctech.net/forum/australi...ght-racer.html
dildil is offline
Old 05-16-2010, 09:45 PM
  #2715
fullout's Avatar
Default tcs racer racing rubbers
Today i ran my 104 with rubbers for the first time. The car is stock and the surface was sugar watered blacktop at about 15 C. I should mention the car is tcs legal, to be run in tcs events.
first i tried the optional front and rear rubbers. I found the car pushed into corners and spun as soon as you applied throttle out of the corner. Then i tried a softer spring in the front and it reduced understeer a little, but still the on power oversteer.
After that i tried the kit front rubbers and what i found was, it didn't understeer anymore but any throttle input would induce a spin(better grip with these tires).
I have 2 sets of optional rears, the ones i was running which i installed the insert. Now i glued up a set without the insert at all, anybody have any insight as to how this is going to work out for me? I won't be able to test for a week or so.
fullout is offline
