Tamiya F104 Pro!
#226
Is anyone running F1 cars on asphalt banked ovals? All we have here to run on other than a clay off road is a 1/4 scale tri oval. I was thinking this may be fun with a brushless geared to the hill for some hot nasty speed.
so... anyone doing this? I was wondering about tires, foams or rubber... and does anyone make capped tires for the F1 cars? (like BSA? makes for the pan cars)
thanks for the help
WaWa
thanks for the help
WaWa
#227
edit*
#228
Well in the end i went Chrome - still got a bit tooo do but its getting there
Enjoy the pics here is the link to my build: http://tamiyaf104pro.blogspot.com/
#229
At the place I am going to race at, They alternate tires on given race days from foam to rubber. Kit comes with foam. TRG has been recommended. Does anyone know if they will mount on the tamiya wheels for the F104. Or will this require some alterations? Possible F103 wheels, or are the TRG wheels made for the F104?
#230
#231
i hope tamiya or someone comes out with a rubber option for these cars
#232
btw i did find ATS www.atsmodel.com who makes rubber slick wheels and tires for the f103 and f104 but can't seem to find any place on-line where i can place an order
#233
http://d-drivesportsenglish.com/inde...roducts_id=448
#235
#236
these cars being so light they should not be to hard on the foam tires and be to light for rubber tires to work properly
#237
here's the front wing to help complete the 2009 spec look
#238
We went for a budget ESC:
Brushless ESC
50A
Input : 7.2 Ni-cd/Ni-mh, 7.4V-11.1V Li-po
Output : 360W
Support : 4500kv For 1/10 Touring, 4000kv For 1/10 Buggy
Weight 55g Incl Fan
Size : 50 x 26 x 16.5 mm
3000KV Brushless Motor
Shaft : 5mm
Size 540 / 50mm
For 1/10 Buggy
Going to be using a lipo 4000 - 5000 for max fun run time
Brushless ESC
50A
Output : 360W
Weight 55g Incl Fan
Shaft : 5mm
Size 540 / 50mm
For 1/10 Buggy
#240
are you using Tamiya spray cans for chrome? what is the color code?
Thanks.
