Tamiya F104 Pro!
#1846
Thanks guys. The black did turn out better than I though it would. I'm not sure if I would recommend it though, as you lose the nose shape of the car, because you obviously can't black out the lower portion of the body. The red tape I used there helped, but it's not quite as good.
Does anybody know what the stock rear spring is rated at? I've got some green AE springs as well as Xray C2.2 springs lying around and I wonder how they would compare.
#1847
I believe these flush mount plugs are the answer, should work without any modifications.
http://www.nexusracing.com/product_i...oducts_id=3067
#1849
You can always get the "foam" car and get the rubber tires if your track races rubber.
Tires are wear items.
#1850
At the Coliseum we hope to transition to rubber tires for club races. Our track has so much traction, I think that the rubber tires will do well. I have a set of the tires, but cannot find the wheels available anywhere yet.
Mr. Banks plans to bring his F60 this weekend if he can get it completed. The F60 has the rubber tires.
So, get your F104 and come school us Mortals like usual.
#1852
#1854
Can anyone owning the F60 show how the front wheel covers are mounted, also the size of the screw holding it down?
#1855
I MUST agree, looks super sick... That gives me an idea what my F60 will look like in all black. Much props! This is reguarding Wheelnut's 104.
#1856
These are my new Shimisu rubbs w/ gold rims. I plan on gluing mine, due to the speeds I'll have to achieve to beat my mentor...
Should look sick with my all black F60.
Just wondering, can someone pm me about getting my pics front and center like those pics that are real big, so that you guys don't have to click to see? I'd like to be able to just see a big pic that I upload!
#1859
I use a 400 - 600 grit wet/dry sand paper to "rough-up" the diff rings prior to installing. I also use Associated diff lube on the diff balls.
#1860
I adjust the tightness of my diff only to the point where I'm barely able to rotate the spur while holding both rear wheels. However, when rotating a single wheel by hand, the diff should feel smooth and not overly gritty or bumpy.
