Old 04-12-2009, 09:06 PM   #1
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
Default Motor timing question
quick question, i havent run/tuned a electric motor in years, if im holding the motor in hand looking down, endbell on top/can below, do i turn endbell twords right, looking down, to crank up the juice? thanks, the timing label is worn out...
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 04-12-2009, 10:18 PM   #2
or is it twords the left when looking down endbell first, can below..
Old 04-12-2009, 10:27 PM   #3
Trips's Avatar
Trader Rating: 16 (100%+)
Holding the can in your hand with the endbell facing you, turn the endbell counterclockwise to advance the timing (more RPM and generally more power)
MARSHAL!!
Trips is offline   Reply With Quote
Old 04-13-2009, 01:32 PM   #4
thanx ill give it a shot!!
Old 04-13-2009, 03:32 PM   #5
Trips's Avatar
Going to Jackson this weekend? (I assume you're not racing electric at Floyd Bennett)
MARSHAL!!
Old 04-14-2009, 09:22 AM   #6
NO MY MOTORS IN, JUST GOTTA GET TO BK HOBBIES TO PICK UP AND THAN BREAK IN PROBALLY NEXT WEEK,WHAT DO YOU RUN 1/8
TOMMY
Old 04-14-2009, 10:16 AM   #7
bigz's Avatar
this will also result to additional heat on the motors right? is there a max setting for the timing in the counter clockwise position?
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 04-14-2009, 10:30 AM   #8
niznai's Avatar
Well, the tell tale sign is that at some point it will run in reverse.
Measure revs and stop when you hit maximum, but remember you might have no torque left. Best if you can have some load on the motor when you test, so you can be sure it can still pull.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
Hot Bodies Cyclone D4 EP buggy Mike Schumacher Electric Off-Road 1921 10-06-2014 12:33 PM
ORL2 SUMMER SERIES Dave Mahr Racing Forum 948 04-07-2014 10:11 PM
Ask Steve "The Evicerator" Weiss TeamButter Electric On-Road 7088 07-16-2011 06:01 PM
vector X11 Tulsa TC3 Electric On-Road 6 12-21-2008 10:05 AM
STOCK motor forum porkybmx Electric On-Road 2817 12-11-2007 02:20 PM
