Top TC3 hop-ups
Old 12-06-2003, 09:08 PM
ajg
Registered User
ajg's Avatar
Default Top TC3 hop-ups
What are the top hop-ups I should get on my TC3? I'm going to start racing it again if I can get it to handle good again. I have a racer kit with carbon fiber drive shaft, and that's it. Whats a good stock motor?
Thanks Andrew
ajg is offline
Old 12-07-2003, 12:45 AM
tnstantheman's Avatar
Default hop ups
Hello. i like the threaded shocks there easy to set tweak .i hated putting the clips , i started with a fatory team and removed most of the aluminum it was heavy and slowed the car down in stocki run the carbon cvds and center shaft it seems to spool up faster
does your car have the droop chassis?
tnstantheman is offline
Old 12-07-2003, 05:00 AM
I know its not a Hop-Up but
Practice!!!!!!!!!!!!!!
Smalls is offline
Old 12-07-2003, 07:48 AM
ajg
Registered User
ajg's Avatar
I don't need to practice. I am one of the top stock class racers at my track. (some of my lap times are a second slower than the mod class)
I guess I'll just upgrade my electronics.
ajg is offline
Old 12-07-2003, 09:23 AM
Maybe if you practiced, you WOULD BE the top stock class racer.
Smalls is offline
Old 12-07-2003, 09:39 AM
howard hudson's Avatar
THIS THREAD IS GETTING FUNNY
I would say something but I dont want to hurt anybodys feelings......................... oh what the heck.
So by upgrading your electronics does this mean you are not going to use your manuel speed control anymore????? j/k LMAO
howard hudson is offline
Old 12-07-2003, 10:05 AM
Wow, I guess, Barry Baker, Josh Cyrul, Musami, Hara, Spashett can all stop practicing......
IMPACTPLAYR is offline
Old 12-07-2003, 10:09 AM
ajg
Registered User
ajg's Avatar
Ok, you guys need to get a life.
ajg is offline
Old 12-07-2003, 10:13 AM
No we all need more practice....
Btw: in all honesty you really need to get the belt drive conversion for the TC3... it's part number is #LOSA0251
Old 12-07-2003, 10:16 AM
ajg
Registered User
ajg's Avatar
Thanks, where can I find that?
Are you talking about the xxx-s?
Because I have the rtr one.
ajg is offline
Old 12-07-2003, 10:17 AM
aaawwww come on just having some fun
order it from PANDA
Old 12-07-2003, 10:20 AM
ajg
Registered User
ajg's Avatar
whats Panda?
ajg is offline
Old 12-07-2003, 10:25 AM
koabich's Avatar
Default Top Hop-Ups
These items will make your car better...mostly lighter and more responsive, which is ever so important in the stock class:
-Upgrade to a full "Factory Team TC3." In your case it would probably be cheaper to by the kit and start new!
-Acer Ceramic Ball Bearings
-IRS Aluminum Imput shafts
-IRS composite Dogbones
-Stay with the Associated C/F drive shaft
Depending on the track, moving the batteries closer to the drive shaft can help greatly. Not really sure if blueprinting the diff cases truely helps you on the track but it does help the "WOW" factor at the track. Do a search for these in the forum.
koabich is offline
Old 12-07-2003, 10:27 AM
HERE YA GO!!!!
https://www.ssl-stormerhobbies.com/c....pl?pn=LOS0251
BTW: the RTR just isn't the same!!!
