Best Dyno
Old 12-17-2003, 06:24 PM
  #31
dtm
dtm's Avatar
I have the CS.....as previously mentioned, the power source can be a pain to getting consistent reading. After charging a pack you normally have to do a few dummy runs to take the peak off the pack so you can get consistent readings. Also, it will struggle to do 9T and below. The manufacturers answer to this is to run 2 packs in parallel.....this works but sends all the readings haywire (ie. you cannot compare your 10T with 1 pack against your 9T with 2 packs)
However, overall it does do the job and it is pretty small. You just have to be careful how you use it to get some comparable numbers.
dtm is offline
Old 12-17-2003, 07:00 PM
  #32
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Is Schumacher selling the CS dyno?
wyd is offline
Old 12-17-2003, 07:59 PM
  #33
Scrubb's Avatar
i would just buy tuned motors from a guy that has a Turbo dyno, let them do all the work so i get to do all the playing! :0)
Scrubb is offline
Old 12-17-2003, 08:45 PM
  #34
dtm
dtm's Avatar
That would be good for the first few packs...then you true your comm....change your brushes and be lost at where your motor is........
dtm is offline
