Old 12-26-2009, 11:19 PM   #106
MaxRain's Avatar
Bob, got the following error msg after installing in windows 7. Any ideas on how to get the program going..
Gordon "slow is fast"
Stock Car - Xray T3 EU Rubber, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06, and I run all Tekin ESC's - Youtube Channel "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg - Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 12-27-2009, 01:10 AM   #107
Jochim_18's Avatar
Got the same error message on windows 7
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 12-27-2009, 03:34 AM   #108
TryHard's Avatar
Bob, sent you a PM, a few suggestions on their way
I got mine installed easily on Win7 Starter on the new netbook... so not sure about the issues there :s
| THard.co.uk | Xray | MuchMore |
Old 12-27-2009, 08:14 PM   #109
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by BobW View Post
Greg, Connecting the two haves is the next logical step. To make it 100% true though need to connect both sides, and connect the front and rear, and add the springs. That was my original idea but became too complex for a first project. We'll see how deep the snow gets this winter.
How's that song go, "let it snow, let it snow, let it snow"?
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 12-27-2009, 10:13 PM   #110
MaxRain's Avatar
What version of windows 7 are you using? 32 or 64bit?
I have 64 bit, and tried to update the .net framework and got an out of order message from microsoft as they are working on correcting some issues. Not sure what issues they are as none were mentioned.
Old 12-27-2009, 10:28 PM   #111
MaxRain's Avatar
attached is another error msg screenshot
Old 12-28-2009, 06:28 AM   #112
BobW's Avatar
Sorry guys I have no idea why the program doesn't work on Windows 7. I've only tested it on XP and Vista and don't have a system that runs Win7 yet.
The error message appears to have something to do with the database engine which is Microsofts SQL Compact Edition. I'll look into it and see what I can find out. It could be a problem with the 64 versus 32 bit edition as well. I know someone had an issue with this earlier and solved it by downloading the 64 bit ASP.net files from Microsoft. Someone might try that.
BobW is offline   Reply With Quote
Old 12-28-2009, 07:34 AM   #113
BobW's Avatar
OK I have an idea. Go to >Control Panel >Add or Remove Programs and scroll down the list of installed programs and see if the following program is listed:
Micrsoft SQL Server Compact 3.5 SP1
If you have any other Compact version installed then use add/remove program to uninstall it before you install the correct version.
The correct version is found here: http://www.microsoft.com/Sqlserver/2...s/compact.aspx Make sure you install the correct 32 or 64 bit version for your system. Hopefully that will solve the problem.
Suggest someone volunteer to try this and make sure it works. I don't want to be responsible for screwing up someone system.
Old 12-28-2009, 07:40 AM   #114
MikeXray's Avatar
Trader Rating: 73 (100%+)
I have it running on 32bit w7 with no issues. Let me know if you need me to verify any installed program versions.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-28-2009, 10:25 AM   #115
TryHard's Avatar
Same, mines a 32bit version on the netbook. Ed
Old 12-28-2009, 09:53 PM   #116
MaxRain's Avatar
Bob, I looked into this and discovered that I had the SQL Server compact 3.5 SPI installed and also the Server 2005. I uninstalled the 2005 version, but I think it wasn't necessary. Anyways, I downloaded the 2.5MB file, low and behold it worked..
Old 12-29-2009, 12:28 AM   #117
Jochim_18's Avatar
I got it to work guys this very usefull when setting up your car. Now you can actually look at your suspension how it travels when the car is cornering and how much tire is making contact on the ground.
Old 12-29-2009, 06:22 AM   #118
BobW's Avatar
Great MaxRain glad it worked. I'm fairly sure what is happening is when you install the program it installs the 32 bit asp.net and SQL Compact files if it doesn't find any of the required files on your system. So even though you had the program installed it was the 32 bit version not the 64.
So for anyone who running a 64 bit machine and having problems you need to install at the very least the file MaxRain did.
Old 12-29-2009, 10:25 AM   #119
vabroom's Avatar
Thanks, Max Rain. I uninstalled the SQL server, then installed the SP1 version. Had to installed both the 86 and the 64bit. Works like a charm. Even though Tekin is coming out with a 64bit program for their esc, I wonder if this was the problem.
vabroom is offline   Reply With Quote
Old 12-30-2009, 09:36 AM   #120
BobW's Avatar
TryHard, check your email.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 08:26 PM
XXX-CR Thread Matt Howard Electric Off-Road 5778 04-03-2017 01:45 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
