Old 04-19-2009, 07:14 PM   #61
BobW's Avatar
OK The bug is fixed. Thanks to bkSpeedo for reporting the problem.
New version has been uploaded and can be found here.
http://www.mediafire.com/file/4m4tgm...CentreV162.zip
Tha manual is here
http://www.mediafire.com/file/ylfxnr...UserManual.pdf
Installing the new version will mean that the database will be re-installed as well. If you have models you need to preserve then I suggest using the Alt-PrintScrn method to copy a screen capture to word. There is another method but it involves finding and copying the Database file which is a little involved because it is not in a normal location. If anyone wants to try this method let me know and I'll post instructions.
To install the new version you must first un-install the old version. Just go to control panel and then add/remove programs. Then just install the new version as before. The microsoft apps do not have to be downloaded.
BobW is offline   Reply With Quote
Old 04-27-2009, 03:58 PM   #62
hey bob another suggestion is to allow the user to input different frt and rear tire dimensions on the same setup ( for offroad cars ) currently you have to create two seperate profiles inorder to get the right results.
Speedpassion USA Team Driver
Schumacher USA Team Driver
Lucky 13 rc graphics
Remember this..... Heaven and Hell are really not places, just your state of mind.
JdogL is offline   Reply With Quote
Old 04-27-2009, 04:05 PM   #63
BobW's Avatar
JdogL, I'm working on a new version right now that should cover that. Should have some animation too. Would you be interested in Beta testing it when it's ready?
Old 04-27-2009, 09:47 PM   #64
Smile
bob definatly yes! send it my way
Old 04-27-2009, 10:07 PM   #65
bkspeedo's Avatar
Bob,
I sent you an email with a new bug I found.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 04-29-2009, 05:11 PM   #66
ok bob got a new one. i keep getting a pop up saying the index was outside the bounds of the array.
Old 04-29-2009, 07:51 PM   #67
BobW's Avatar
Sorry for not getting back sooner my internet has ben down for the last day. New version has been uploaded that corrects this bug.
Old 04-29-2009, 08:28 PM   #68
Anybody work out the dimensions for a TA05 IFS?
RepaF1 is offline   Reply With Quote
Old 05-01-2009, 03:26 PM   #69
bob whats the story on the version you want me to test?
Old 05-01-2009, 03:38 PM   #70
BobW's Avatar
I'm still working on it. It will probably be a few weeks yet. I only get a couple hours every few days to work on it. Just peck away at it while watching TV in the evenings.
Send me a email and I will email it to you when it's ready for testing.
Old 05-23-2009, 09:29 PM   #71
BobW's Avatar
A new version is currently being Beta tested. I have made several improvements based on your suggestions.
  • New Format for Setup page
  • Separate Tire width, Dia and camber values can be set for front and rear
  • Chassis roll animation routine
  • User can enter arm angle to calculate camber gain
  • Save and Load the model settings on the Setup Page
I have a couple of Beta testers but wouldn't mind a couple more. I really want to sort out any bugs before I release this version.
Old 05-24-2009, 06:38 AM   #72
BobW's Avatar
One last thing. If anyone would like to share models they have created I will add them to the database and include them with the next release.
I posted a screen shot method earlier that is the simplest way to do this.
Old 05-24-2009, 10:24 AM   #73
Default error fix
I had a problem installing this program under vista home pro x64. Fixed the problem by installing sql server x64 update. Hope it helps somebody.
hawk1x is offline   Reply With Quote
Old 05-28-2009, 06:16 PM   #74
BobW's Avatar
Ran in to a few snags with the new version. Hopefully will have them sorted tonight.
I was hoping to add a bunch of models in addition to the new features to this version but so far I have zero. Come on guys sharing is a good thing. That's how we all learn. There is a screen capture method that I posted earlier which is the easiest way to do it. The program has been downloaded by more than 300 of you so there must be models out there. Send them through to:
[email protected]
Thanks in advance for sharing!!!
Old 05-29-2009, 10:01 PM   #75
BobW's Avatar
OK the new version is ready. Sorry no new models. Nobody wants to share.
Here is the link.
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 08:26 PM
XXX-CR Thread Matt Howard Electric Off-Road 5778 04-03-2017 01:45 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
