Old 12-30-2011, 03:55 AM   #166
daleburr's Avatar
Originally Posted by BobW View Post
It's taken a little more than a year but it's finally finished. RC Crew Chief will be a reality in a couple weeks. I am just doing some Beta testing and then the full version will be ready. For the time being you can view some slide shows on my "RC Crew Chief 2012" Facebook Page that explain some of the features.
There is also a Demo program available for download here.
http://www.mediafire.com/?d3njj3qlqdo54xx
"The procedure entry point DecodePointer could not be located in KERNEL32.dll".
What is the minimum OS needed?
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 12-30-2011, 05:31 AM   #167
BobW's Avatar
I've installed it on XP SP3, Vista and Windows 7 with no issues so it should work. Try to google the error you posted and see what you find.
Bob Wright
http://rccrewchief.wrightdesign.ca
BobW is offline   Reply With Quote
Old 12-30-2011, 06:00 AM   #168
Conrad's Avatar
Good news, I'll try it when I'm back on a windows machine.
Swith Racing [www.swithracing.co.uk]
Conrad is online now   Reply With Quote
Old 12-30-2011, 06:10 AM   #169
BobW's Avatar
When the program installs it checks to see if you have some Microsoft apps like .net and .SQLCE installed on your machine. If you don't then it will install them for you if you give it permission. Maybe you didn't let it install these. If you don't the program will not run. Try to uninstall the program from add/remove programs and the reinstall it.
What version of windows are you running?
Bob Wright
Old 12-30-2011, 07:36 AM   #170
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Bob,
It looks excellent, fantastic job!
I have a few comments/questions/possible additions if you don't mind.
1. On the suspension calculator, can you display Ride Frequency in addition to or instead of Ride Rate? These are more commonly used in industry and motorsport to qualify proper ride stiffness overall as well as front to back relative stiffness.
2. I love that you've done various cornering situations with tire loads - this is great. How is this taking to account tire steering angle and the resulting slip angle difference relative to the rear? I feel it is not really accurate to say Oversteer or Understeer unless you have added this piece. Lateral force is much, much more slip angle sensitive than it is load sensitive. What I think could be done is to estimate tire compliance for a general tire and use a defined corner radius. You could then develop an estimated slip angle/tire load plot for the front and for the rear. I think you would have to assume for this exercise that increasing slip angle always increases lateral grip given that you do not know what the peak or dropoff rate is. From there you can calculate estimated tire lateral grip. The braking and acceleration with cornering will be tricky to estimate loads. It's not perfect and would definitely have some amount of error, but would get you much closer to being able to quantify Over and Understeer.
Brian
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 12-30-2011, 08:15 AM   #171
BobW's Avatar
Originally Posted by Brian McGreevy View Post
Bob,
Brian
Thanks Brian, It's taken a long time and about 20,000 lines of code to get where it is now. Thanks for your suggestions:
1. I can certainly add the ride frequency. Shouldn't be a problem. The front/rear ride rate is actually the ride stiffness. This is the terminology used in the text book I based the program on. Is that what you mean?
2. The whole tire issue is a problem to simulate without having good tire data to base the tire model on. Since there is no data on Vertical/Lateral load versus slip angle for RC tires I decided to stay away from this for now and just look at weight transfer. In a furture version I may try to implement the "Majic Tire Formulae" to get a better representation. Right now the push loose tendency is based on "wedge" alone. It is intended to be an indicator to help access the direction the changes you make on the handling page are taking you.
I actually tried some skid pad testing at our track which was interesting but difficult to draw any conclusions about since the skid pad went on and off the track racing line so the grip level changed drastically. I may revisit this to try and get the 'g' limit for a tire so at least you have one data point to base a tire model on. Measuring slip angles is a whole other problem.
Keep the comments coming.
Bob Wright
Old 12-30-2011, 10:17 AM   #172
Conrad's Avatar
Well at the time of writing I was on Opensuse Linux, now I'm on Fedora. When I get back to the Windows XP partition I'll be giving it a try, looking forward to see the advancements from the previous program which was ace
Old 12-30-2011, 02:12 PM   #173
bkspeedo's Avatar
This looks awesome, just from playing with it for 10 minutes there's a lot stuff i can learn and hopefully improve my setup.
A few questions
1. I know you've spent a tremendous amount of time writing the code for this app, and you may have this planned, help tips for fields or information calculated.
2. When you maximize a window with-in side the app it can not be closed or or un-maximized.
I'll post more when i start using the app.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 12-30-2011, 03:13 PM   #174
BobW's Avatar
A few questions
The full version will have a companion users manual. I'm working on it now.
The maximize/minimize issue is just with the Demo version as some of the menus have been disable. It works fine in the full version
Bob Wright
Old 12-30-2011, 06:54 PM   #175
kakaroctt's Avatar
thanks man...manage to install at one shot..great animation,cool graffic n a lot can learn...
but where did it go?after playing with,i close the window but when i try to reopen,i cant find it anymore...'u cant start app from this location because it is already install in a different location'...
LEGGERE LE ISTRUZIONI PRIMA DELL' USO !
kakaroctt is offline   Reply With Quote
Old 12-30-2011, 07:36 PM   #176
BobW's Avatar
Sounds like you are trying to re-install it. The install program doesn't place a shortcut icon on your desktop. Click on >Start and then >all programs and look for RCCrewChiefDemo.
Bob Wright
Old 12-30-2011, 07:56 PM   #177
BobW's Avatar
Just uploaded another Slide Show to the "RC Crew Chief 2012" facebook page. This one, Part 3, focuses on the features of the "Motor Manager". The demo version doesn't allow all the features to be explored, particularly the Dyno Analysis and Build Model features.
There are three slide shows on facebook. If you haven't already looked at them I suggest you do as it may answer some questions.
Bob Wright
Old 12-30-2011, 08:10 PM   #178
kakaroctt's Avatar
WORKS!!
Silly me..
thanks dude..dont want to lost this usefull program...
facebook link?
Old 12-30-2011, 09:06 PM   #179
Lessen's Avatar
Send a message via MSN to Lessen
Hmmm. Not able to install. I get
"The application requires that assembly System.Data.SqlServerCe Version 3.5.1.0 be installed in teh GlabalAssembly Cache (GAC) first.
I'm not a pc guy by any means..
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 12-31-2011, 08:19 AM   #180
BobW's Avatar
The installer will install that assembly for you. I believe it asks you first if it is OK to install. If you don't allow it to install the program will not work. These assemblies are from Microsoft so they are safe.
It's also possible your AntiVirus program or firewall may be blocking access. If you use Norton you may have to temporarily disable it.
Bob Wright
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 08:26 PM
XXX-CR Thread Matt Howard Electric Off-Road 5778 04-03-2017 01:45 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
