Old 09-12-2010, 08:14 PM   #136
2xs
Thanks for the great program BobW....I know what kind of struggle it is to teach yourself VB. But what a fun struggle it is.
I will have to see if I can put it to good use for my Cyclone TC and Sprint 2 Sport.
2xs is offline   Reply With Quote
Old 09-24-2010, 04:12 PM   #137
Trader Rating: 26 (100%+)
Any one have the numbers for a TC5R? I thought i seen someone say that they were posted but i could not find them.
unlucky is offline   Reply With Quote
Old 09-26-2010, 02:34 PM   #138
Airwave's Avatar
I just create a model for TCX using the latest Hara IIC setup...
The fact is that I don't modelize the different anchor point, or shimes... The graph is too small to click on the different points...
Anyway, it's easy to modify existing model...
I'm doing screenshots and I upload them...
EDIT:
Airwave is offline   Reply With Quote
Old 09-26-2010, 02:40 PM   #139
JayBee's Avatar
Trader Rating: 31 (100%+)
I haven't checked the whole thread but has anyone done this for the XRay T3 yet?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-07-2011, 05:23 AM   #140
daleburr's Avatar
Bob, this is a very useful program.
I'd been looking at purchasing a full-size motorsport app and using it for RC, so having your app for free is very nice!
I run several different cars and it's very nice being able to compare roll-centres between cars. I'm changing cars shortly so it will be very useful seeing how the new TC6 compares to my old Yokomo BD.
It's also very useful for seeing what effect setup changes have and then seeing how they correlate to track testing.
There are a few little bugs I'd like to fix, any chance of getting the source code? I'm a software developer by trade so I'm sure I could pick it up very quickly.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 01-07-2011, 05:34 AM   #141
BobW's Avatar
Thanks Dale
I'm actually starting to work on a program that will provide even more help with setup. Very similar to full scale app but built for RC.
If you let me know what the bugs are I will fix them. Don't really want to release the source code.
Bob Wright
http://rccrewchief.wrightdesign.ca
BobW is offline   Reply With Quote
Old 01-07-2011, 06:07 AM   #142
heretic's Avatar
Hi Airwave ! I see you've also put this little gem to good use.
BobW : a million thanks again for your program. May I ask why you'd prefer not share the code ? I have absolutely no competence in this domain , I am just curious, huh-huh
In an attempt to modelize the suspension of my offroad B4, I've met some difficulties in accounting for the massive amount of front kickup (around 30 degress) How could I include this parameter in relation to the others ? My general car suspension abilities are a bit limited although I kind of understand the essential points i.e. camber gain and roll center. In my previous modelizations I've worked on TCs so the kickup and toe-in angles were ( in my understanding) pretty negligble.
Further suggestions : one thing I've always been curious to see, apart from the parmaters already available, is a way of obtaining a graph which would show the dynamic roll center / camber gains. I might very well be wrong but I gather one could get the same static roll center with different upper and-or lower arm positions, and yet have a totally different dynamic responses, for instance linear or exponential, or logarithmic or anything else. Same for camber gain and other angle variations. If I am wrong someone correct me, I am here to learn. I am not saying I would be able to exploit these extra features, I am just very, VERY curious.
Same for the shock lever and angle ( bottom and top anchor) : being able to get a visual quantification of the lever effect and its variations throughout the travel of the supsension would be super nice.
My main source of info is Staniforth's "competition car suspension" BTW. Don't hesitate to redirect me to particular chapters if someone has this book and don't want to spend 20 minutes typing.
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 01-07-2011, 06:46 AM   #143
daleburr's Avatar
Originally Posted by BobW View Post
Thanks Dale
The ones I can currently think of are:
  • On the 'Model' tab, whenever you exit an edit control, it changes back to the 'Model' view, which means you have to keep changing back to 'Variables' view when you're putting in a new car and are working through the variables.
  • On the Setup tab, it sometimes loses the selected pickup points and ends up with random RC values. I think this happens when switching between cars. It doesn't always do it, but it's quite frequent. Picture here of the result (note the missing circles):
    http://www.rc-timing.com/other/RCBug1.Png
I would also like to see how much the RC changes with chassis roll. Given that the 'animate' button can show what happens during roll, I guess it's not too much work to add a 'RC change for 5 deg chassis roll' type of output. This would be the #1 priority for me as the three things that the setup affects are initial RC, camber change and RC change.
With that said I want to repeat that this is a great tool, and clearly the result of a lot of work (which is why I'm using it rather than writing one myself ).
Team Xray
Old 01-07-2011, 07:47 AM   #144
BobW's Avatar
I guess I am just selfish when it comes to the source code. I spent 6 months working on the program and want to expand the capabilites. I might ask a few $ for the next one to help recover my investment in purchasing software, books and of course many, many hours of my time.
The program was basically developed for sedans so I ignored the effect of Kick-up and anti-squat. As you noted these angles are normally small. In your case if you set the height of the inner hinge as the average between the fore/aft mounting points it should be close. So if your hinge pin is 40mm long and the kickup is 30 degrees then the average would be 40/2*sin(30) = 10mm. Add that value to the height of the hinge pin above the chassis and it should be close.
I already have the math worked out for the shock angles and positions. Just not in a useable form. That will be part of the next version.
Dynamic roll centre changes require both sides of the car to be modelled. To be perfectly accurate you really need to model all 4 corners. I hope to include some form of this in the next version.
Bob Wright
Old 01-07-2011, 07:51 AM   #145
BobW's Avatar
I'll have a look and see if I can replicate the bugs. As you know sometimes these things can be hard to find.
Thanks for all the feedback guys. Glad you are finding it helpful.
Bob Wright
Old 01-07-2011, 11:05 AM   #146
heretic's Avatar
Thank you again Sir.
Old 01-15-2011, 12:03 PM   #147
BobW's Avatar
I've had a look at your bugs with limited success.
The first one is not a bug, I intentionally programed it this way as I didn't expect a lot of data entry on the model screen, just maybe tweaking a value. The intent was to instantly show the user graphically the effect of the new value. If you plan on making lots of changes to the basic suspension geometry it may be easier to use the new model method. On this screen the "Variables" graphic is static. This method would create a new model though.
I haven't been able to recreate the second bug. I've tried all different combinations with no luck. Which version of the program are you using?
Bob Wright
Old 01-19-2011, 05:54 AM   #148
sandsurfer's Avatar
Trader Rating: 20 (100%+)
Send a message via Skype™ to sandsurfer
Default Install Problem
BobW - I have read all posts in regards to your app. Does it work with windows 7? The reason I ask is because after I install I get this error message when trying to start the app.
Your reply would be appreciated. Thanks Gary
sandsurfer is offline   Reply With Quote
Old 01-19-2011, 06:14 AM   #149
BobW's Avatar
Sandsurfer,
It runs on fine on Windows 7. At least I haven't had any problems.
It looks like the database software did not get installed. Did you go through the full install process? The are a number of microsoft programs that must be downloaded and installed for the program to work. The installer will do this automatically but I believe it asks permission first. If you decline then the program will not work.
Suggest uninstall/reinstall and see what happens.
Bob Wright
Old 01-20-2011, 08:52 PM   #150
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Sandsurfer,
Are you running on 64-bit Win7? I am on 64-bit Vista and have the same error.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 08:26 PM
XXX-CR Thread Matt Howard Electric Off-Road 5778 04-03-2017 01:45 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
