what are crystals?
what are crystals?
I heard something about crystals what are they?
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
Re: what are crystals?
I have 8
XS3 baby
XS3 baby
you can also buy crystal less transmitter and receiver. you can check Hitec and Novak.
i have a JR XS3 which has 8 frequency on board
xs3
i have the XS3 with 30 frequencies... 75mhz baby!!!
never had a frequency since i got it
Regional Moderator
A homogenous solid formed by a repeating, three-dimensional pattern of atoms, ions, or molecules and having fixed distances between constituent parts.
The unit cell of such a pattern.
A mineral, especially a transparent form of quartz, having a crystalline structure, often characterized by external planar faces.
A natural or synthetic crystalline material having piezoelectric or semiconducting properties.
An electronic device, such as an oscillator or detector, using such a material.
A high-quality, clear, colorless glass.
An object, especially a vessel or ornament, made of such glass.
Such objects considered as a group.
A clear glass or plastic protective cover for the face of a watch or clock.
Slang. A stimulant drug, usually methamphetamine, in its powdered form.
adj.
Clear or transparent: a crystal lake; the crystal clarity of their reasoning.
[Middle English cristal, from Old French, from Latin crystallum, from Greek krustallos, ice, crystal. See kreus- in Indo-European Roots.]
[Buy it]
Source: The American Heritage® Dictionary of the English Language, Fourth Edition
Copyright © 2000 by Houghton Mifflin Company.
Published by Houghton Mifflin Company. All rights reserved.
crystal
( P ) crystal: log in for this definition of crystal and other entries in Merriam-Webster Medical Dictionary, available only to Dictionary.com Premium members.
Source: Merriam-Webster Medical Dictionary, © 2002 Merriam-Webster, Inc.
crystal
\Crys"tal\ (kr?s"tal), n. [OE. cristal, F. cristal, L. crystallum crystal, ice, fr. Gr. ????, fr. ???? icy cold, frost; cf. AS. crystalla, fr. L. crystallum; prob. akin to E. crust. See Crust, Raw.] 1. (Chem. & Min.) The regular form which a substance tends to assume in solidifying, through the inherent power of cohesive attraction. It is bounded by plane surfaces, symmetrically arranged, and each species of crystal has fixed axial ratios. See Crystallization.
2. The material of quartz, in crystallization transparent or nearly so, and either colorless or slightly tinged with gray, or the like; -- called also rock crystal. Ornamental vessels are made of it. Cf. Smoky quartz, Pebble; also Brazilian pebble, under Brazilian.
3. A species of glass, more perfect in its composition and manufacture than common glass, and often cut into ornamental forms. See Flint glass.
4. The glass over the dial of a watch case.
5. Anything resembling crystal, as clear water, etc.
The blue crystal of the seas. --Byron.
Blood crystal. See under Blood.
Compound crystal. See under Compound.
Iceland crystal, a transparent variety of calcite, or crystallized calcium carbonate, brought from Iceland, and used in certain optical instruments, as the polariscope.
Rock crystal, or Mountain crystal, any transparent crystal of quartz, particularly of limpid or colorless quartz.
Source: Webster's Revised Unabridged Dictionary, © 1996, 1998 MICRA, Inc.
crystal
\Crys"tal\, a. Consisting of, or like, crystal; clear; transparent; lucid; pellucid; crystalline.
Through crystal walls each little mote will peep. --Shak.
By crystal streams that murmur through the meads. --Dryden.
The crystal pellets at the touch congeal, And from the ground rebounds the ratting hail. --H. Brooks.
crystal
n 1: a solid formed by the solidification of a chemical and having a highly regular atomic structure 2: a crystalline element used in various electronic devices 3: a rock formed by the solidification of a substance; has regularly repeating internal structure; external plane faces 4: colorless glass made of almost pure silica [syn: quartz glass, quartz, vitreous silica, lechatelierite] 5: glassware made of quartz 6: a protective cover that protects the face of a watch [syn: watch crystal, watch glass]
Source: WordNet ® 1.6, © 1997 Princeton University
crystal
Concurrent Representation of Your Space-Time ALgorithms.
A recursion equation parallel language.
["A Parallel Language and its Compilation to Multiprocessor
Machines or VLSI", M.C. Chen, 13th POPL, ACM 1986 pp.131-139].
(1994-12-06)
Source: The Free On-line Dictionary of Computing, © 1993-2003 Denis Howe
crystal, MI
Zip code(s): 48818
crystal, MN (city, FIPS 14158)
Population (1990): 23788 (9541 housing units)
Area: 14.9 sq km (land), 0.2 sq km (water)
Zip code(s): 55428
crystal, ND (city, FIPS 17060)
Population (1990): 199 (96 housing units)
Area: 1.7 sq km (land), 0.0 sq km (water)
Zip code(s): 58222
Source: U.S. Gazetteer, U.S. Census Bureau
crystal
(Ezek. 1:22, with the epithet "terrible," as dazzling the spectators with its
brightness). The word occurs in Rev. 4:6; 21:11; 22:1. It is a stone of the
flint order, the most refined kind of quartz. The Greek word here used means
also literally "ice." The ancients regarded the crystal as only pure water
congealed into extreme hardness by great length of time.
Source: Easton's 1897 Bible Dictionary
crystal
crystal: in CancerWEB's On-line Medical Dictionary
Source: On-line Medical Dictionary, © 1997-98 Academic Medical Publishing & CancerWEB
adj.
[Buy it]
crystal
crystal
crystal
crystal
crystal
(1994-12-06)
crystal, MI
Zip code(s): 48818
Zip code(s): 55428
Zip code(s): 58222
crystal
crystal
adj.
[Buy it]
crystal
crystal
crystal
crystal
crystal
(1994-12-06)
crystal, MI
Zip code(s): 48818
Zip code(s): 55428
Zip code(s): 58222
crystal
crystal
adj.
[Buy it]
crystal
crystal
crystal
crystal
crystal
(1994-12-06)
crystal, MI
Zip code(s): 48818
Zip code(s): 55428
Zip code(s): 58222
crystal
crystal
Sleighty
