Old 12-06-2003, 09:18 AM   #16
That is a very neat installation! Do you have any glitching troubles (be honest) with stuff mounted to the cap?
I nopticed I had to move my cap to several different locations to prevent a very subtle glitch I was getting.
NitroJohnnyD is offline   Reply With Quote
Old 12-06-2003, 09:30 AM   #17
Where can I get that diode?
Smalls is offline   Reply With Quote
Old 12-06-2003, 10:14 AM   #18
rc-zombies's Avatar
I have not experience any glitching at all.. as long as the diode is at least 1 to 2" from the motor. I'm using the 3PK w/HRS reciever on 27mhz.
Old 12-06-2003, 10:21 AM   #19
rc-zombies's Avatar
I got mine from Tower.
Old 12-06-2003, 03:04 PM   #20
Fire's Avatar
you should be able to get that diode at any shops that sell novak stuffs
Fire is offline   Reply With Quote
Old 12-06-2003, 09:42 PM   #21
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
If I was you I wouldnt remove it...... Novak engineers have put it there for a reason. When you say "remove" do you mean take it out from the stock posistion and mount it somewhere else? Or take it out totally? Cauz yeas in my 12thscale car I did remove the heatshrink and mounted the diode unit against the case with two black zip-ties. Basically did that just to make the wiring look neater. lol But whatever you do, dont remove it because it does void factory warranty
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 12-06-2003, 09:54 PM   #22
rc-zombies's Avatar
true...but after 90days...you can do what ever you want to it.
also if you have the earlier versions without the diode...like I did ...doing my mod was simple..less wires hanging.
Old 12-06-2003, 09:57 PM   #23
Actually NOVAK's warranty is 120 days...
Old 12-06-2003, 11:16 PM   #24
Fire's Avatar
novak will still get you coverred if something goes wrong, they have excellent service
Does it matter if i place the diode a but further away from the motor? it is kinda tough to keep that diode close to the motor on my SD. for closer or further i mean the length of the wire from the doide to the motor tabs
Old 12-07-2003, 09:25 AM   #25
tc3 racer sc's Avatar
Default what a good setting for mod/ stock on carpet
what a good setting for mod/stock on carpet plse help thxs reggie
tc3 racer sc is offline   Reply With Quote
Novak 13.5 Question? chris72983 Electric On-Road 64 04-18-2007 04:06 AM
Novak BL Question BlackKat Electric On-Road 5 03-14-2005 02:14 PM
novak spy question S-T-R-l-K-E-R Electric On-Road 1 03-03-2004 12:29 AM
Novak GT7 Question tmeeks Electric On-Road 2 02-16-2004 06:42 AM
Novak c2 question KINGZJ Electric On-Road 0 02-18-2003 09:58 PM
