Old 04-03-2009, 04:50 PM   #1
Three's Avatar
Default Gen-X, Single cell lipo shock mounting
The shock does not clear the plastic case on my Gen-X.
Does (did) anyone else have this problem? What was done to elevate this? Pics if possible. Any set-up help would also be nice.
Electric good..........
Three is offline   Reply With Quote
Old 04-03-2009, 10:21 PM   #2
Trips's Avatar
Trader Rating: 16 (100%+)
I built the car as per the manual and the shock clears the SMC LiPO just fine.
MARSHAL!!
Trips is offline   Reply With Quote
Old 04-03-2009, 10:26 PM   #3
Do you have the small spacer under the antenna ball stud side to the shock?
if you do the lipo should fit without the bars that are used for the normal cells
Gorden
light is offline   Reply With Quote
Old 04-04-2009, 06:03 AM   #4
Three's Avatar
Oops...... I had changed the lower shock mount for ease of battery removal. I knew there was something wrong. Many thanks !!!
