Old 12-02-2003, 11:24 PM   #1
Default Reading your tires?......
This past weekend I raced at the new local indoor track which is small (8 sec. laps) and tight. I was running on Sorex 24's with thin med-firm sorex inserts. Due to the 2 right hand sweepers I smoked a pair of tires. The tires on my left side overheated and "shreaded" quite badly.
Here's my set-up....
Losi XXX-S G+
Front
3rd hole out on the shock tower
40 wt. oil/ 56 piston
0 toe
-1 deg. chamber
4 deg. caster blocks
2 deg. kick-up
2nd hole out for camber link on the tower
arms middle
Rear
2nd hole out on the tower
1/2 deg. standard off-set hubs
-1 deg. chamber
0 deg. anti-squat
2A chamber link (2nd hole on the tower inside hole on the hubs
Batts forward (3300GP's)
Trinity monster stock
Sorex 24's
Sorex med-firm inserts
Yokomo 12 spoke 24mm rims
Protoform opel vauxhaul body
Freshly paved aspahalt track , indoor, tight
This is by far the absolute fastest set-up I had on this track, but it tore up my left side tires in 2 heats (the first heat they showed bad signs of wear, but I didn't rotate them because I didn't wanna tear up a full set of tires.
The tires are wearing (in order from worst to best)
Left front- severally blistered
Left rear- badly blistered
Right front- minor blistering
Right rear- wearing but not bad at all
How can I get better life out of my next set of tires?? med-firm thick inserts? Front sway bar? Any other suggestions?
I totally don't like how my car feels with "unmatched" tires or inserts from front to rear so that is definately not an option.....
Thanks in advance!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 12-03-2003, 01:13 AM   #2
What is the temperature of the track surface? Which Sorex inserts are you running: thick, thin, or super thin? What is the stiffness of the insert: medium or firm? That will help in figuring it out. I usually only use 24R's on carpet or on cold asphalt surfaces. On asphalt I usually use 28R's with cool track temps.
James Nguyen is offline   Reply With Quote
Old 12-03-2003, 02:15 AM   #3
black-knight's Avatar
R/C Tech Charter Subscriber
put foams on your car.... sorted!
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 12-03-2003, 07:14 AM   #4
James- as I stated the inserts are Sorex MED-FIRM THIN inserts, the track is down right cold.... I can't be sure of the exact temps, but the air temp is between 30-50deg..... and after racing all day you can feel the cold from the asphalt in your legs....... it isn't the most pleasant thing....LOL
Black-knight - No it wouldn't be sorted...LOL Foams raise their own set of problems..... ALSO as I stated I run a LOSI XXX-S G+, so I run limiters in my shocks instead of droop screws.... This can make it a pain for between round tuning....
Old 12-03-2003, 07:34 AM   #5
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
IMPACTPLAYR Where are you racing at now? Is this the track down towards Chambersburg? Coming to RCO anytime soon?
Brian
ST Racing Concepts (STRC)
Old 12-03-2003, 07:46 AM   #6
Brian- what track down towards Chambersburg???? I do need a new place to play...LOL
Hopefully I will be coming up before Christmas with a few freinds.... Do you remember a good foam set-up for the LOSI?
Old 12-03-2003, 07:54 AM   #7
wyd
Tech Legend
wyd's Avatar
I have a fairly good setup that Craig Xavier gave to me as it makes the car very aggressive and twitchy. IF you are at RCO I will show you the setup sheet that I have stiff for the car. It is a spool setup. I also have my orignal setup for a diff that was pretty smooth overall and very consistant.
I thought you raced at that track off or route 70. I think a few of the Xray guys went their. They race asphalt but I thought the place had a small inddor carpet as well. I saw a new place opened up, I think in GlenBurnie if I remembered correctly.
Old 12-03-2003, 08:23 AM   #8
Yeah, I race at the track in Hagerstown. They did have a crappy indoor carpet track, but now it has been paved.... mostly smooth.... Glen Burnie is a little far for racing for me. I would rather take a trip to RCO....
BTW: your set-up sounds better for me, I can always dial in more steering if needed...... I've never ran a spool before, but wanna try a one-way sometime soon...LOL
Old 12-03-2003, 10:20 AM   #9
fatdoggy's Avatar
IMPACTPLAYR - Can you say tyre warmers? You did have them on for quite a while before you ran.
fatdoggy is offline   Reply With Quote
Old 12-03-2003, 10:51 AM   #10
Nope- the warmers where on for 15 minutes, but I only had them connected to the P/S for 4-5, after that they just kept the tires above ambient temp. and I didn't even use them before the last race.....
I am gonna try med-firm THICK inserts and then a front sway bar.
However I most likely will race at RCO next, so I gotta get me some purple foams...LOL.
I'm also gonna work on a droop fix......
Old 12-03-2003, 10:52 AM   #11
Sorex only makes med and firm inserts, they dont make a med-firm insert. try going to an "A" thick insert in firm compound.
Old 12-03-2003, 11:05 AM   #12
newracer's Avatar
How about a higher temp tire? 28R? If 3 out of the 4 tires are blistering and showing a lot of wear it seems to me you need a higher temp tire. You might need to use the warmers more though.
newracer is offline   Reply With Quote
Old 12-03-2003, 11:06 AM   #13
I have to disagree:
here are the inserts I have--
https://www.ssl-stormerhobbies.com/c...pl?pn=SRXMB24M
and here are the thick inserts--
https://www.ssl-stormerhobbies.com/c...pl?pn=SRXMA24M
And you say I should try these correct?
https://www.ssl-stormerhobbies.com/c...pl?pn=SRXMA24F
THANK YOU VERY MUCH JAMES!!!!!
Old 12-03-2003, 11:08 AM   #14
highwayman's Avatar
i use to race on carpet using 28deg sorex tires and found 32deg better all around, didnt overheat or wear out the tires as quickly as the 24deg.... might i sugggest trying out a higher compound next time.
and , yes i would also try "fuller" inserts.
highwayman is offline   Reply With Quote
Old 12-03-2003, 11:09 AM   #15
I chose the 24R's because the track temps I am experiencing fall just about in the middle of their rated temps....
I will post pics of the "damage" later tonight.....
Doing some reading for myself vs. Being lazy Turbo Joe Electric Off-Road 13 09-28-2007 03:26 PM
Reading your rubber tires Section 8 Electric On-Road 1 06-01-2007 10:27 AM
Reading the comm? pserve Electric Off-Road 2 05-24-2007 09:53 PM
MAH Reading ftfl99 Rookie Zone 3 11-25-2006 11:30 PM
reading dyno's snopro31 Electric On-Road 7 12-11-2003 11:02 PM
