Like Tree6Likes
Schumacher Mi4
Old 01-09-2010, 12:04 PM
  #1321
CA
Thanks spokesman Papespeed!
Originally Posted by turbodog
aluminum hexes
U3525 wide hex (comes with Mi4)
U2991 medium hex (comes with Mi3)
U3221 super narrow hex (option part)
U3570 ???????? don't see this one listed
Right then hex's.
We only have 2 widths of hex, narrow and std.
U3525 - Std kit wide, what we use in the rear.
U2991 - Narrow width (but now discontinued)
U3221 - Narrow width (but with no oring) designed on request for wheels with shallow hex fitting as it has more contact area because no oring.
U3570 - Narrow width with O ring (new version of U2991)
Hope that helps.
CA is offline
Old 01-10-2010, 06:25 PM
  #1322
Jerry P's Avatar
Trader Rating: 44 (100%+)
Has anyone noticed excessive play in the lay shaft on the MI4 LP? it appears that the washer included in the kit is too small and the spur tends to move left and right way too much for my liking. I grabed a washer from Mike Haynes today that seems to make it fit much better but if i over tight it binds the spur up.
Jerry P is offline
Old 01-11-2010, 01:21 AM
  #1323
Ritchie T's Avatar
Exclamation
Yes, i took it for its first run last Fri and it came off with marks down the side of the spur where it had touched the lil carbon piece that joins the bulkheads together
Ritchie T is offline
Old 01-11-2010, 04:49 AM
  #1324
steveonamission's Avatar
That shouldnt of happened, i have play in mine, but it doesnt go anywhere near the the translink plate? Did you make sure you installed the translink plate correctly, they go round a certain way,as there differently shapped either way... when secured correctly, the spur cant touch it even with the little play from kit.
steveonamission is offline
Old 01-11-2010, 05:03 AM
  #1325
Jerry P's Avatar
My spur wasnt touching anything but it does have a lot of play. I'm going to get pick up some thing shim's that fit over the lay shaft and take out some of the play. The schumacher spur is thing I dont want to start wrecking them. Right now i am very careful with the pinion because it has to in the right spot of the spur is not fully touching the pininon when it moves.
Jerry P is offline
Old 01-11-2010, 06:27 AM
  #1326
Ritchie T's Avatar
Exclamation
Sorry didnt write that out properly the rolley eyes were because i put them on the wrong way round
Old 01-11-2010, 06:35 AM
  #1327
Oh right, never have been able to master reading ones rolley eyes
Old 01-11-2010, 06:46 AM
  #1328
Yeah i understand that...though mine doesnt have as much play as whole width of a pinon? I would deffinatly be shimming it if it moved that much.
Old 01-11-2010, 06:57 AM
  #1329
Ritchie T's Avatar
Exclamation
Won down the local club though with the links grinding away at the spur
Old 01-11-2010, 08:16 AM
  #1330
Think of the possibilities if you built it properly in the first place :P Just messing, good job.
Cant wait to get mine outside, not a fan of carpet season
Old 01-11-2010, 08:54 AM
  #1331
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
I know that feeling. Bring on the summer asphalt! Carpet
Owen RaCing is offline
Old 01-11-2010, 09:03 AM
  #1332
Haha summer asphalt? We dont have that here, its just asphalt
Old 01-11-2010, 09:09 AM
  #1333
Well asphalt hits in the summer. So thats what I call it. Summer Asphalt.
Old 01-11-2010, 09:22 AM
  #1334
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Haha we run asphalt all season!
I can't wait till summer!
BlackedOutREVO is offline
Old 01-11-2010, 10:04 AM
  #1335
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
I can't wait till i get that call after you "race" with a car broken in half cause you cant drive
abailey21 is offline
