Like Tree6Likes
Schumacher Mi4
Old 12-06-2009, 08:11 AM
  #1081
I got my Mi4LP on Friday evening. Thanks Adam. Got 1/2 of it built at the track yesterday. Can't wait to get it on the track. Hope to run some laps on Wednesday. We have the Grand Slam Race this weekend.
SRW141 is offline
Old 12-06-2009, 10:41 AM
  #1082
Trader Rating: 82 (100%+)
Kenny,
i just started to put your set-up on my mi3.5 and to get 48.2mm between centerlines on the ballstuds i have to put 7mm worth of link washers on which will work but to get the 54.2 mm between centers in the rear i have to run 10mm of link washers and on the mi3.5 the locating pin sticking out of the bulkhead for the link mounts are not long enough so i have to go to work and machine up some new pins and use those for the set-up..
i do have a quick question : you say on the set-up sheet you are running short arms up front only . you think i would be ok running short c/f on the rear as well? and would i have to add 1mm to your current screw block spacer setting to make up for the difference in arm length?
jeff jenkins is offline
Old 12-06-2009, 10:43 AM
  #1083
what is the street price for the mi4lp?
Old 12-06-2009, 11:04 AM
  #1084
also another question : on the mi4 set-up sheets the shock towers have an added hole my qustion is was the hole added to the inside or to the outside of the tower?
Old 12-06-2009, 01:03 PM
  #1085
Inside.
MattW is offline
Old 12-06-2009, 01:43 PM
  #1086
thanks.
Old 12-06-2009, 06:55 PM
  #1087
All I have left to do is put the electronics in it. Can't wait til Wednesday to hit the track. Mi4Lp is sweet.
SRW141 is offline
Old 12-06-2009, 08:27 PM
  #1088
skypilot's Avatar
Trader Rating: 14 (100%+)
who was it that said they used a 9650 steering servo on thier sedan?
it fits the LP perfectly using the existing holes in the chassis, you just have to flip the forward servo mount to the other side of the servo.
btw, complete with body and TP5000 1375.
skypilot is offline
Old 12-07-2009, 04:11 AM
  #1089
I installed a 9650 steering servo. No problem.
SRW141 is offline
Old 12-07-2009, 05:16 AM
  #1090
skypilot's Avatar
thanks, I was explaining your thoughts on ... your high tq servo is only has strong as your saver.... to some friends and they all agreed, never thought of it that way, I'll give it a go.
skypilot is offline
Old 12-07-2009, 07:19 AM
  #1091
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
$479.99
abailey21 is offline
Old 12-07-2009, 07:28 AM
  #1092
MikeXray's Avatar
Trader Rating: 73 (100%+)
Kenny,
I would be worried about the ballstud mounts with that many shims, haynes ran 3mm all around when he had the Mi3.5, we know those things can bend so I would keep a close eye on them. I keep looking at the bulkheads trying to find a way to rig up the Mi4 plates
MikeXray is offline
Old 12-07-2009, 10:49 AM
  #1093
definately i know what you mean so i am going to make longer locating pins and then i am going to have shims on the pin as well to beef it up.
but i am looking at the car as well to see if i could machine up a mount to run mi4 plates on it.
Old 12-07-2009, 10:50 AM
  #1094
Originally Posted by abailey21 View Post
$479.99
thanks.
Old 12-07-2009, 10:51 AM
  #1095
hey ritchie,
are you going to have the lp with you at the next hanger race?
