Schumacher Mi4
#1037
they should cross over fine. other than chassis flex (which is probably not that different), everything else is relatively unchanged. if the new chassis is at all stiffer, you can probably thin the top deck web until you get the same flex....
done.
done.
#1039
#1041
Where can i get a good carpet/foam set up for the LP car?
#1042
#1043
#1045
#1046
#1048
So where do i find Kenny Lambert?
