Like Tree6Likes
Schumacher Mi4
Old 11-30-2009, 08:43 AM
  #1006
Originally Posted by cuttingedge View Post
But is the Mi4LP going to be better than the Mi4 ? From looking at it all the photos it looks like the same car with a narrower chassie so surly it will ballence the same as they have not moved the lipo further out just brounght the chassie in ??????????????
I love the Mi4 its fantstic
The lipo is further out than the standard mi4 allowing you balance the chassis 100% mine weighs 1345
Smartypants is offline
Old 11-30-2009, 11:22 AM
  #1007
Mopar's Avatar
The battery doesn't sit any further out, the narrower chassis just makes it seem that way.
Mopar is offline
Old 11-30-2009, 11:27 AM
  #1008
seaball's Avatar
seaball is offline
Old 11-30-2009, 11:43 AM
  #1009
Originally Posted by The Bear View Post
Gotta put this out there again. Lamberts rubber carpet setup is freakishly good. We put a 1st time rubber tire driver down with it (not an advanced driver either) and he did just fine with it...... it is an amazing drive.
how many times i got to tell you stop talking about me
thanks again for letting me drive your car until they build more, it drove really well i wanted more initial steering and a bit less mid/exit but that could be due to missing those 2 things from kenny's setup
i would be wrenching it right now but i forgot to get some 1mm shims from you. see you again Tuesday and I'm hoping to keep pace with all you Mi4 guys.
Rob S is offline
Old 11-30-2009, 02:17 PM
  #1010
cuttingedge's Avatar
Do i get am MI4LP or stick with the MI4 Which i have won many A finals at club level and broken track records with ???????????????
Is the Mi4LP Faster ??????????????
cuttingedge is offline
Old 11-30-2009, 02:27 PM
  #1011
Wrong put both chassis plates side by side and your see the mi4lp chassis pushes the lipo out around an extra 6mm away from the centre line of the car you could achieve the same thing if you hang the lipo over the side of the standard chassis though
Old 11-30-2009, 02:32 PM
  #1012
Just change the lower chassis plate and buy the lipo retainer and your done! they are the major changes really. It is always nice to have a new car though
Old 11-30-2009, 02:38 PM
  #1013
Originally Posted by jdm19turn View Post
where can I buy some of the new camber plates Kenny uses on his setups so I can try some his setups on carpet
Thanxs Joey
Not sure when they will be available. My best suggestion would be to run 1gr. in the front and 1 gr. in the back but go into the inner hole on the hub. Going to a 0gr. rear and inside would be very close roll center wise (maybe slightly lower by fractions) than what we run now. The distance between a 0 and -2 and the distance between hub holes is both 3mm.
We actually both broke a plate each this past week. So we are running a 1gr. in the front with the same -2/outside in the rear for now.
JoelV is offline
Old 11-30-2009, 02:51 PM
  #1014
stormperson's Avatar
I can attest to Kenny's set up being dialed
stormperson is offline
Old 11-30-2009, 02:57 PM
  #1015
seaball's Avatar
that it. i'm in.
seaball is offline
Old 11-30-2009, 03:15 PM
  #1016
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Keep the old one The only thing I want from the LP is the new layshaft. I have everything else, maybe the new chassis. But im not sure if I want it or not
BlackedOutREVO is offline
Old 11-30-2009, 03:42 PM
  #1017
The Bear's Avatar
Originally Posted by seaball View Post
that it. i'm in.
Thanks Mark, I've been ebombing him but it took you to push him over the edge. Granger is next.
The Bear is offline
Old 11-30-2009, 05:55 PM
  #1018
MikeXray's Avatar
Trader Rating: 73 (100%+)
What's the length of the turnbuckle in that config? I'm still rocking the MI3, and I have the rear links at full length at the moment, inside hole.
MikeXray is offline
Old 11-30-2009, 08:18 PM
  #1019
racer x 1's Avatar
Trader Rating: 27 (100%+)
hey guys im curious about this car, and i was wondering if you think that this would be a good car for 13.5 on high bite asphalt? also does this kit require anything more than what comes in the box or just fine tuning? thanks in advance. much appreciated!
racer x 1 is offline
Old 11-30-2009, 08:24 PM
  #1020
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Look at Blackedoutrevo's set up some pages back. He's running 13.5 asphalt. Nothing special except silver HPI springs. He has gone back to long arms.
Awesome car for everything.
Owen RaCing is offline
