Schumacher Mi4
#781
you need to be careful with the molded blocks, as stated, they have built in toe, so with a 1mm spacer front and rear it has like 2.5 rear toe, when your adding or removing spacers your actually twisting or putting a bind on the molded blocks. make sure your hinge pins don't bind
#782
You gotta make his drips go both directions... M.C. Escher-like. That way it will be a trip even for those not trippin'...
#785
Ah, I didn't flip the belts nor will I space the lipo off the chassis. With the ppd tray and lipo weight taped to the lipo, I am very close to balanced and close to 1500g. I always try to run to ROAR spec, even at a club even that doesn't tech. My motor is shoved in some, but not much. I try to keep it balanced with the weight as inward as possible on both sides. For fun Ill take pics of my finished setup later this week. (As long as the guys wanting paint from me don't hussle me too much ;-)
#786
Roar Rules:
8.10.5.1
Weight
Minimum – Foam: 1418 gr
Minimum – Rubber: 1500 gr
For some reason I thought your lipo was hanging off the edge. Sorry. Hmm, Ill play around with the belts then. Already hurt my front grey belt. Boy is it soft. Was just checking tension, gunned it then slammed on brakes, skipped a TON...
Tension was set a tad tighter than my TC5... I wish the cams had finer adjustment, or if Schumie released cams that were offset to the standard positions.
8.10.5.1
Weight
#788
Hello all.
I am seriously considering switching from my xray 009 to the mi4.
Is there anyone brazen enough to give me their 2 cents as to why they like the car and perhaps some pointers to consider straight out of the box build and setupwise?
I'm running on carpet.
Rubber.
Marcos...Your the post master, any thoughts?
Thanks in advance,
Dave.
Rubber.
Thanks in advance,
Dave.
#789
Hello all.
Rubber.
Thanks in advance,
Dave.
Rubber.
Thanks in advance,
Dave.
#790
Roar Rules:
8.10.5.1
Weight
8.10.5.1
Weight
#791
Finally got legit run time in on the car for the first time. Amazing. Thank you Adam and Kenny. We ran 10.5 foam today. Quite interesting with a serpents back in the track.
Haynes, I should have listened to you way back when you tried selling me a losi (at the time) at 360 and I should have switched to a Schumacher behind you as well.
#792
Hello all.
Rubber.
Thanks in advance,
Dave.
Rubber.
Thanks in advance,
Dave.
I switched from Xray last season to Schumacher this season and I was turning lap times on par or faster then on my Xray on my Schumacher's maiden run.
Setup Tips:
-The stock pivot blocks have toe already in them if shimmed the same front to rear, so always check toe on a setup station.
-Chris Grainger's Maritime carpet setup should be an awesome starting point if your track is high traction or has a groove going. If you're on a track with little to no groove/grip, I can send you a base I started with.
#793
Larcher, I'll let you know when I settle on the colors....
First night with the Mi4......... "I'm freaken' out man!"
This car is AWESOME!!!!!! Simple and simply a great drive. SO easy to work on, solid, and I'm just very happy with it, especially for a first run. So impressed.
#794
Hello all.
Rubber.
Thanks in advance,
Dave.
Rubber.
Thanks in advance,
Dave.
#795
Very good night with the Mi4. Got 10.5 foam setup pretty close to dialed in.
