Like Tree6Likes
Schumacher Mi4
Old 09-04-2009, 10:03 PM
  #586
Trader Rating: 15 (100%+)
Default vegas
Car is all done and ready for vegas ..Thanks to AJ Paints For the new paint!
Attached Thumbnails Schumacher Mi4-dscf1247.jpg   Schumacher Mi4-dscf1248.jpg   Schumacher Mi4-dscf1249.jpg
AARON YOUNG is offline
Old 09-04-2009, 10:17 PM
  #587
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
I remember reading in the redrc.net review that it would be wise to purchase a "circlip" tool. What size and where can I purchase one? Does Stormer Hobbies sell one, as I am going to put an order in with them.
Also, about the new arms. I will be running on med-high traction asphalt, would it be wise to purchase the new short arms? What about the old Mi3 alloy arm mounts?
rezenclowd3 is offline
Old 09-04-2009, 10:22 PM
  #588
A absolute yes on the arm mounts.If you want to run sweep ,kickup or antidive.For the circlip pliers i went to harbor freight and bought a small pair.
Old 09-04-2009, 10:29 PM
  #589
Korey Harbke's Avatar
You should be able to hop into sears and find some too. Or if you're REALLY cheap you can grind down the tips of some body scissors....
Korey Harbke is offline
Old 09-04-2009, 11:12 PM
  #590
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally Posted by BlackedOutREVO
Haha nah. I will just wait till his Tekin stops going fast
I could probably beat you with orion equipment
STLNLST is offline
Old 09-04-2009, 11:13 PM
  #591
STLNLST's Avatar
Originally Posted by Owen RaCing
You gonna try the pit lane line too? That's how I should have got Sawyer back for taking all my parts.
I am the only racer to ever go thru pit lane at full speed at Speedworld. I'm a legend man.
STLNLST is offline
Old 09-04-2009, 11:32 PM
  #592
jdm19turn's Avatar
nice paint job! good luck to all the team in vegas keep us update on how it's going
jdm19turn is offline
Old 09-05-2009, 05:41 AM
  #593
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
Yes on the short arms and Harbor Freight on the circlip pliers
abailey21 is offline
Old 09-05-2009, 09:14 AM
  #594
Owen RaCing's Avatar
That's for sure!
I haven't laughed that much in a day of racing in years.
Owen RaCing is offline
Old 09-05-2009, 09:19 AM
  #595
yokemad's Avatar
yokemad is offline
Old 09-05-2009, 09:48 AM
  #596
jhock's Avatar
I have a question. How are you guys measuring droop with the MI4? The setup sheets say one thing but then trying to achieve it is another. Im guess the way they are measuring is the chassis flat on the setup board and the bottom of the arm from the pitboard? When you do this it has tremendous amount of droop! I used to use the lift method but it doesnt seem right.
One more, the rear end keeps sliding out on entry through mid turn, how you guys fixing that? I put thicker shims on the rear camber link and it seems to help, also removed the swaybars with also gave alot of grip all around, any suggestions? I am running stock setup, minus swaybars and camber shim!
jhock is offline
Old 09-05-2009, 12:48 PM
  #597
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
I measure my droop on droop blocks to the bottom of the arm under the hubs.
if you are racing on asphalt try my set up , its feel that is very good, plenty of steering and rear end grip.
Its the last set up on this link
http://www.racing-cars.com/usa/searc...e1=prodvalue14
Marcos.J is offline
Old 09-05-2009, 05:12 PM
  #598
Thanks Aaron and Adam. Made an order through Stormer for the Mi3 gray belts, gray blades, and hard and medium arms. I did not order the alloy mounts as the order plus car is well above $500 now...
I'm not one to use sweep, or adjust the angle of the hinge pins for antidive or kickup generally so I will wait.
Old 09-05-2009, 10:52 PM
  #599
Scott B's Avatar
Trader Rating: 47 (100%+)
Your a Legend, in your own mind. Russ drove through pit lane full throttle YEARS AGO.
Besides Slash racers do it every Oval slash race at SWR, lap after lap!!!
Anyways full speed with a tekin is SLOWER then a stock Slash!!!
Scott B is offline
Old 09-05-2009, 10:54 PM
  #600
STLNLST's Avatar
[QUOTE=Owen RaCing;6304460]That's for sure!
Did you see me on the stand??? I had tears in my eyes and I think you actually saw a black man turn red I was laughing so hard. Good thing no one was standing in pit lane
Originally Posted by yokemad
I ciuldn't have said it better. A picture is worth a thousand words
STLNLST is offline
