Like Tree6Likes
Schumacher Mi4
Old 07-11-2012, 09:12 AM
  #3616
olhipster1's Avatar
Trader Rating: 102 (100%+)
Default thanks
nice read.
if you can direct me to where I can find your ‘I use it everywhere’ setup
thank you
olhipster1 is offline
Old 07-11-2012, 10:53 AM
  #3617
Correct, they are the same.
Originally Posted by grippgoat
What is the difference between the new CXL layshaft, and the old original Mi4 layshaft? They look basically the same.
-Mike
MattW is offline
Old 07-11-2012, 02:26 PM
  #3618
Swamp Rat's Avatar
The CXL layshaft is now supported both sides with a larger screw cap that screws into the rear mount.
The Rat
Swamp Rat is offline
Old 07-11-2012, 03:50 PM
  #3619
The Rat
The original Mi4 was that way, too. They didn't change to the single-sided one until the Mi4LP. I think I still have the old Mi4 one from a used car in my parts box, so I'll pull it out and throw it in.
-Mike
grippgoat is offline
Old 07-16-2012, 08:13 PM
  #3620
Anyone know what size the holes are in the kit 3-hole pistons?
-Mike
Old 07-17-2012, 08:28 AM
  #3621
Craig W's Avatar
-Mike
1mm i think
Craig W is offline
Old 07-17-2012, 09:15 AM
  #3622
olhipster1's Avatar
-Mike
i do believe 1mm..
some drill out to 1.1 mm..
i prefer to use the tamiya pistons.. makes them a little smoother..
Everyone please don't forget when placing pistons on...use a .1 shim to remove all play in piston...this will make a huge difference in how the car handles.
Old 07-17-2012, 12:28 PM
  #3623
Originally Posted by olhipster1
i do believe 1mm..
Have you ever used entire TRF shocks? The overall length is very close, but the TRF shocks have less shaft travel. I was gonna give 'em a try next race day just to see how it feels.
-Mike
Old 07-22-2012, 09:10 AM
  #3624
Car Breaker's Avatar
I need help with hot weather setup, the tract is medium to high grip asphault with ground temp of 45C+ and air temp of 35C at night, the tire I have is sorex 40 with MA insert, my car can bearly turn until overheat kick in to slip the rear like crazy. any suggestion in reducing traction ?
Car Breaker is offline
Old 07-22-2012, 05:34 PM
  #3625
GSM Storm's Avatar
Trader Rating: 114 (100%+)
Hi
What springs and oil are you running.
Regards
Gary
GSM Storm is offline
Old 07-23-2012, 01:13 AM
  #3626
Originally Posted by GSM Storm
Hi
Regards
Gary
I am using Schumacher White spring and 40wt oil
Old 07-23-2012, 04:30 AM
  #3627
poochy's Avatar
Try 36 or 32s, or 28s in the rear...keeping 40 up frnt..(assuming track surface is still arounnd 45c)...see if the tail stays plantd once the tire heats up..if it does...might want to try another brand of tires/inserts...
poochy is offline
Old 07-23-2012, 05:33 PM
  #3628
GSM Storm's Avatar
Running mod in Brisbane in summer, using HPI silver springs all round, track temp 20 to 30degC, 40wt oil, 30 to 40degC, 45wt, 40 to 50degC 50wt oil, if you are running stock drop the oil weights by 5.
I would try 36R sorex / Schumacher yellow inserts, 45wt oil.
Regards
Gary
Old 07-23-2012, 06:56 PM
  #3629
olhipster1's Avatar
you can try the two extremes...
change the front oil to 42 1/2 with HPI springs...
or
soften the springs all around and let the car roll way more..lazy it up a little bit.
then play with upper shock position, this will impact the car greatly.
will depend on your driving style.
Old 07-27-2012, 11:06 PM
  #3630
Chris Grainger made the A at worlds. If it's wet, maybe his british mojo will bring him through the field.
-Mike
