Schumacher Mi4
#3601
Trader Rating: 101 (100%+)
http://www.rctech.net/forum/r-c-item...r-mi4-cxl.html
If anyone is interested selling one of my spare cars.
#3602
What aluminum shims are you guys using? 3x6 don't fit. I don't like the clips. I want to use aluminum shims so please help me out.
#3603
i think it's a little bigger than 3x6... 3x7
my caliper is broken...i am sure someone can measure up the internal.
part number is
U3131
18pieces = 3 different sizes.
easiest part to use fits everything on the car, hingepins (outer & inner), shock mounts, camber link plates..etc.
sorry I don't have the HB part number...edit I think it's part number Z814, it shows as 3x6 but I believe the inner diameter is slightly larger. The Schui is better.
i just opened the bag and threw away the header cars.
part number is
U3131
#3604
If you want to use alloy shims, you need them with 1/8 internal hole. The 3mm ones are too small.
We usually use either HPI or TOP Racing ones. I don't have any part no's to hand.
#3606
be sure to remove some material from the inner steering knuckle...no friction.
#3608
No problems so far and not had any reason to look at them since i fitted them about 2 months ago.
#3610
Yes 4 black sliders, and 4 grey sliders in the pack now.
#3611
use the black sliders only in the front...and put a little grease in the slider, it does wonder.
i can get about 2 months out of a set in the front...running 17.5...not sure how long they would last with a modified..
but I prefer this design to others....quick and easy and relatively cheaper to run compared to other brands.
T6 covers are super sturdy.
#3614
Hey guys.
Getting ready for the worlds this month!
Finished another blog entry!
Have fun reading here!
Martin
Martin
