Like Tree6Likes
Schumacher Mi4
Old 01-03-2012, 10:06 PM
  #3226
olhipster1's Avatar
Trader Rating: 102 (100%+)
Default MI4CX
just picked up a MI4CX to test
i can say the car is quite interesting, builds very nice. Driveline is butter smooth, driveshafts look absolutely bullet proof.
Are there any parts that are must have?
Any mod that must be done?
olhipster1 is offline
Old 01-09-2012, 04:11 AM
  #3227
Anybody tried fitting somedouble joint driveshafts, other than the Spec-R shafts?
JiiIii is offline
Old 01-09-2012, 02:24 PM
  #3228
Default spool cv
hey guys i was wondering if these parts are available in the us u3825, u3823, u3611, g884. any information will help thanks.
tren2.0 is offline
Old 01-09-2012, 04:55 PM
  #3229
outtafocus's Avatar
http://www.amainhobbies.com/advanced...u3823&x=7&y=14
http://www.amainhobbies.com/advanced...hu3611&x=9&y=8
Found these 2 on Amain in about 30 seconds.
But if you want it all, just order direct from Schumacher UK. Fast shipping and easy to deal with. Plus if they don't have it, no one will!
outtafocus is offline
Old 01-09-2012, 06:46 PM
  #3230
olhipster1's Avatar
Default shock building
quick question.
when building the shocks...
are the Clear o-rings better or should I use the Reds?
Old 01-09-2012, 07:11 PM
  #3231
I have used 52mm xray ecs's. Don't see why the spec-r xray ones wouldn't work. They are sure cheaper. They also have a version2 out.
SRW141 is offline
Old 01-09-2012, 09:15 PM
  #3232
thanks man appreciate the link
tren2.0 is offline
Old 01-10-2012, 10:28 AM
  #3233
poochy's Avatar
Originally Posted by olhipster1
quick question.
do not use the clear-use the newer double o-rings (2 blue rings)
the cx's now ship with them:
http://www.racing-cars.com/pp/New_Ca...4CX/U2999.html
poochy is offline
Old 01-10-2012, 10:35 AM
  #3234
poochy's Avatar
narrow front hex (tuning option) and the metal center pulley (stock is not metal) are good to have.
poochy is offline
Old 01-10-2012, 10:42 AM
  #3235
poochy's Avatar
I guess the poor rear grip was more due to chancing track conditions and possibly increased front grip.
Anyone had luck sealing the Spec-R gear diff? I have put Greenslime on the o-rings, and even the gasket on the diff case.
the outdrives can easily be sealed with ae green slime and new orings
but
careful on screwing the case together-overscrewing actually causes the case to not seal and open up.......the screw has sunk to deep and now separates the case....
poochy is offline
Old 01-10-2012, 11:35 AM
  #3236
The blue o rings are intended for the off road shocks. The clear o ring is still Schumacher's prime for the on road shock.
MattW is offline
Old 01-10-2012, 12:07 PM
  #3237
poochy's Avatar
trust me, the clear will leak--again thats why the new CX ships with the blue...AVOID THE CLEAR
poochy is offline
Old 01-10-2012, 05:19 PM
  #3238
outtafocus's Avatar
I have found the Associated red o-rings keep leaking to a minimum. Also should be very easy to get a hold of.
Old 01-10-2012, 05:49 PM
  #3239
GSM Storm's Avatar
Trader Rating: 114 (100%+)
Default Shocks
That"s funny, just sold 3 new kits sent from Schumacher direct and build one for one of the buyers, only clear O Rings in the kit and the red ones that have more drag, funny thing to, 2 of the 3 kits came with 4 white springs and 1 came with 2 blue, 2 white as per normal.
When you buy the rebuild kits you get the blue ones, has been this way for years, they have more drag and keep the dirt out better for offroad.
I have had some shock that leak from new but most have been fine, one shock I had I found that changing the shock shaft fixed the problem, don't know why the original shaft looked fine and was the correct size.
Regards
Gary
GSM Storm is offline
Old 01-10-2012, 05:58 PM
  #3240
GSM Storm's Avatar
Default Spec-r diff
We have done a lot of testing with the Spec-R diff and have found that using a automotive CV grease on the O Rings works great and the thin O Ring for the top from Demon racing in the UK, also using the Tamiya anti wear grease on the gasket helps as well if you don't have the thin O ring.
also if you loose rear grip we have found going thicker in the diff oil helps a lot, we use 1000wt when the track has good grip and 2000wt when it is not so good, AE oil, fresh oil makes a different as well.
This is running Mod with 4.5 turn motors.
Regards
Gary
