Like Tree6Likes
Schumacher Mi4
Old 09-28-2011, 06:31 AM
  #3046
Super Moderator
Marcos.J's Avatar
Trader Rating: 237 (100%+)
Originally Posted by LOSI123
My rear 1.2mm bar is tweaked very bad, what do you guys do to detweak sway bars as the link is not adustable, do you bend the bar
Buy a new one
Marcos.J is offline
Old 09-28-2011, 07:43 AM
  #3047
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
For 17.5 blinky mode, are you guys ushualy running full endbell housing timing ?
Blitzrockey is offline
Old 09-28-2011, 10:43 AM
  #3048
Super Moderator
Marcos.J's Avatar
Yes depending on the track I would run around a 3.8-4.0
Marcos.J is offline
Old 09-28-2011, 12:50 PM
  #3049
poochy's Avatar
thanks for the advise guys, so for rear toe is it every 1mm added to the front of the rear blocks reduces toe buy 1 degree?.
or if thats wrong what is the method on calculator?
The mi4cx manual indicates a .5mm shim affects the rear toe by .6 degrees.
poochy is offline
Old 09-28-2011, 01:21 PM
  #3050
LOSI123's Avatar
Trader Rating: 63 (100%+)
Originally Posted by Marcos.J
Buy a new one
the car came with rear 1.4mm bar, this 1.2mm bar was brand new from packet,
so do you bend them, or are there optional adjustable sway bar links.
LOSI123 is offline
Old 09-28-2011, 01:22 PM
  #3051
LOSI123's Avatar
Thanks a ton Poochy
LOSI123 is offline
Old 09-28-2011, 03:08 PM
  #3052
Thanks, thats about what I run about a 3.8
Old 09-28-2011, 04:24 PM
  #3053
If you've got a nice flat surface, do this:
Put the bar down on the surface. Put one finger in the middle, and another finger on one end. Then press the other end gently to see if there's play between it and the board. Bend the bar to relieve the play. Repeat for both ends, and then flip the bar over and check again.
That's not a great description, but hopefully you can figure out what I mean. Also, holding the bar up and looking at it with the two ends aligned:
eyes) -> \___/
You can sometimes see something out of alignment on one of the outer bends.
-Mike
grippgoat is offline
Old 09-29-2011, 12:46 AM
  #3054
LOSI123's Avatar
eyes) -> \___/
-Mike
thanks bud
I understand
spewing that shumacher dont make an adjustable sway bar link, i know it is short but still could be made i think.
cheers
LOSI123 is offline
Old 09-29-2011, 03:59 AM
  #3055
Benzaah's Avatar
Trader Rating: 24 (96%+)
spewing that shumacher dont make ......
Its just something you have to get used to. They have priorities elsewhere i guess. Like making their own gear diff ( I wish )
Benzaah is offline
Old 09-29-2011, 05:01 AM
  #3056
caltek1's Avatar
Trader Rating: 38 (100%+)
Ben,
I got these links of facebook for new Schui parts.
http://www.racing-cars.com/pp/Manufa...ec_R/G883.html
http://www.racing-cars.com/pp/New_Ca...4CX/U3933.html
Thought some might be interested.
Later,
Calvin.
caltek1 is offline
Old 09-29-2011, 05:23 AM
  #3057
poochy's Avatar
thanks bud
I understand
cheers
Just double chckin that ths is not happenin....the front and rear sway bars are not the same size. Sounds like u r trying to put a 1.2 frnt sway in the rear?
poochy is offline
Old 09-29-2011, 09:43 PM
  #3058
LOSI123's Avatar
Nah ive got the rear on the rear, i checked that ,
LOSI123 is offline
Old 09-29-2011, 11:37 PM
  #3059
Martin Hofer's Avatar
Hey guys.
Here's my solution for adjustable swaybar links! It's an HPI part. There's 2 versions around. the dull full plastic one (pretty cheap) and the shown posh purple version I got :-)
When you use it, you need to make sure it's slopfree. It's quite hard to get them slopfree as you have to compress them a bit to get them smaller, but once slopfree, the swaybar works much much better and the influence on the cars performance is bigger than you would imagine.
That's the unfortunate thing about having bottom mounted swaybars with the links far in, everything needs to be spot on to make it work properly
Martin Hofer is offline
Old 10-01-2011, 07:05 AM
  #3060
Super Moderator
Marcos.J's Avatar
Finally I get to run my mi4 on asphalt tomorrow
Marcos.J is offline
