Like Tree6Likes
Schumacher Mi4
Old 07-26-2011, 05:37 PM
  #2911
Trader Rating: 25 (100%+)
Interested in a good deal check this.....http://www.rctech.net/forum/r-c-item...rage-sale.html
IVAN RM is offline
Old 07-26-2011, 05:54 PM
  #2912
Bobert Ross's Avatar
I know this is the wrong place to post but if you are going to the paved nationals this weekend i will have my 2 Mi4LPs with me as i now have a different car..only cause the track i drive at doesnt stock schumacher parts as i have always loved this car I also have a spec r gear diff NIB..belts, arms, hubs etc..i have a lot of parts..80% of the Mi4LP is used on the Mi4CX..especially the ones that break the most..anyways, it would be great to see a few peeps with a Schumacher come down to Jackson, NJ and put it down
Bobert Ross is offline
Old 08-03-2011, 01:13 AM
  #2913
Brokin Racing's Avatar
Trader Rating: 74 (100%+)
Have any of you guys had any experience with the soft-weave lower decks?
More grip? Worth getting??
Cheers
Brokin Racing is offline
Old 08-03-2011, 01:38 AM
  #2914
Benzaah's Avatar
Trader Rating: 24 (96%+)
Cheers
Yes, Its awesome Jim. I have also converted to a 2.5 top deck now as I found a bit too much flex and now it has a better balance and the car is dialed...
Benzaah is offline
Old 08-03-2011, 05:38 AM
  #2915
Thanks Benzaah..
Old 08-08-2011, 05:50 AM
  #2916
WildManDriving's Avatar
Trader Rating: 30 (100%+)
Titanium screw set for the Mi4LP? Is there only LiteModz? Is there a better way to get titanium screws for the car?
Michael
WildManDriving is offline
Old 08-10-2011, 10:46 PM
  #2917
What does it take to mount Tamiya TRF shocks to an Mi4? Do they work well, in terms of the mounting and overall length and stuff?
I ask, because one of my cars has the coating worn off the shafts, and a set of 4 shafts is about 60% the cost of a set of Tamiya shocks.
-Mike
grippgoat is offline
Old 08-11-2011, 02:42 AM
  #2918
BrodieMan's Avatar
Two sponsored drivers came to my track yesterday with their brand new Mi4's. Damn that's one nice piece of kit I foresee one in my future
BrodieMan is offline
Old 08-11-2011, 06:46 AM
  #2919
Trader Rating: 82 (100%+)
-Mike
schumacher shock are practically tamiya shocks with different caps so you should be fine. you will need the mounting balls for the tamiya shocks to mount them.
jeff jenkins is offline
Old 08-13-2011, 02:01 PM
  #2920
Super Moderator
Marcos.J's Avatar
Trader Rating: 235 (100%+)
can someone tell me the distance between the bulkheads? inner distance where the diff sits, thanks
Marcos.J is offline
Old 08-14-2011, 03:52 AM
  #2921
Any one ahave try a dufferent servo position on ther mi4cx?
I meen lik hb, yokomo ?
Can be Little tight beteen the motor and servo, :/
Zooberg is offline
Old 08-14-2011, 02:49 PM
  #2922
Bulkheads are 18mm, but the bearing spacing is 15.75mm. That's because of the way the diff eccentrics mount.
-Mike
Old 08-15-2011, 10:25 AM
  #2923
Jamesalex's Avatar
Hi, sorry for the stupid question,
I am still running the MI4lp and I still keep chewing the spool cups and drivshafts. Has anyone else been having these issues and I was wondering how these have been sorted, is it a case of Tamiya driveshafts etc or changing the front end to the cx or adapting the spool.
Any advise would be much appreciated
Thanks in advance
Jamesalex is offline
Old 08-15-2011, 12:16 PM
  #2924
Thanks in advance
Front gear diff should make things a bit easier on the parts. You can run the gear diff with the LP shafts and blades. You just leave off the black aluminum ring around the outdrive.
I converted an LP to CX spool and driveshafts, but only ran a couple events with the spool before switching to a gear diff. All of my CX driveshafts (front and rear) are still perfect. I think the slider inserts on the CX spool might wear a bit faster than blades, though. If you do decide to order CX parts, get an extra pack or two of spare slider inserts while you're at it, so you don't have to pay shipping from the UK again so soon.
-Mike
Old 08-15-2011, 05:24 PM
  #2925
skypilot's Avatar
Trader Rating: 14 (100%+)
if you start with good clean out drives and keep a eye on the blades there should not be a problem, if you hit stuff, just take them off and throw them away, there cheap, buy all you can get, change them often.
little tid bit on the cx out drives, you need to keep a eye on them also, and replace them every so often, they will notch and your dog bones will not slide smoothy, in fact, take a wheel off, pop the shock loose, and see how free the arm moves. I believe it has more to do with hitting pipes, then using a spool vs gear diff although with a spool they probably damage easier.
skypilot is offline
