Like Tree6Likes
Schumacher Mi4
Old 04-06-2011, 12:20 AM
  #2611
Magnet Top's Avatar
Default 4 sale Mi4LP and NIP parts - BEST OFFER
Mi4LP and a bunch of NIP parts, Best Offer ( cash / paypal ) for the lot:
Check it out :
http://www.rctech.net/forum/8915714-post8087.html
Ritchie can vouch that I'm legit.
Magnet Top is offline
Old 04-06-2011, 12:51 AM
  #2612
CA
Originally Posted by GSM Storm
Hi all
Some were in this thread it was said that some people were using muchmore "o" rings in the shocks, what color "o" ring are you using.
Regards
Gary
Green, the lighter one of the two.
CA is offline
Old 04-06-2011, 06:06 AM
  #2613
poochy's Avatar
If I build the Mi4CX exactly per the instructions, what setup would I be putting on from the Mi4CX setup page?
---> http://www.racing-cars.com/search.as...e1=prodvalue14
poochy is offline
Old 04-06-2011, 08:02 AM
  #2614
jrxs-r's Avatar
For parking lot I would probably recommend the tarmac low grip to start with and work from there.
jrxs-r is offline
Old 04-06-2011, 02:10 PM
  #2615
GSM Storm's Avatar
Trader Rating: 114 (100%+)
Default "O" Rings
Thanks Chris, do you know were I can get some, that will send to Australia.
Regards
Gary
GSM Storm is offline
Old 04-06-2011, 07:07 PM
  #2616
Hi Guys
I have not seen any discussion regarding the Big Bore shocks, i have only heard of 1 local to OZ guy running them (Hi Jim), and he seems to like them on our low grip bumpy tracks.
What is happening OS, people tried them, liked them, not liked them etc.
Martin your thoughts?
Besercoe is offline
Old 04-07-2011, 01:24 AM
  #2617
Brokin Racing's Avatar
Trader Rating: 74 (100%+)
Hi Bradd, you do get around
Brokin Racing is offline
Old 04-07-2011, 01:30 AM
  #2618
caltek1's Avatar
Trader Rating: 38 (100%+)
Bradd,
Are you thinking of changing car again?
I have them and now that I have some other springs I will test them out. However whilst the car is working with the applied setup, I don't see the point in changing until I need too.
Later,
Calvin.
caltek1 is offline
Old 04-07-2011, 02:04 AM
  #2619
Originally Posted by caltek1
Bradd,
Later,
Calvin.
Schuie, been there done that
Im poor so i cant get a new car if i wanted to, however the big bore shocks have intrigued me, wuldnt mind giving them a try, but with needing springs too its a bit of an investment for a try. Unless you want me to get them ready for you
Jim - You know me, im a RC Tart.
Besercoe is offline
Old 04-07-2011, 01:25 PM
  #2620
...Well, you know me, I like to test stuff, old habits die hard
Give me a couple of weeks Bradd & I'll loan you the big shocks & spring kit & you can have a play with'em
Old 04-07-2011, 10:41 PM
  #2621
Are the only differences between the CX chassis plate and the LP chassis plate the extra hole per bulkhead, and the extra holes around the servo? Or are all the bulkhead holes a bit different?
-Mike
grippgoat is offline
Old 04-08-2011, 04:48 AM
  #2622
Martin Hofer's Avatar
The bigbore shocks always make the car handle a LOT easier! So if you struggle with a very challenging track layout or a car that is a hand full it's time to go bigbore. If not it's good to stick to standard as a car that needs a little effort to be driven keeps you focused and running on the edge
Martin Hofer is offline
Old 04-08-2011, 06:39 AM
  #2623
hi everyone ,need some tips or setups for my mi4cx for a high grib tarmac track . the car keeps fliping over ....and tomorrows race day..runing 13.5 ,no timing . thanks
oldnoob is offline
Old 04-08-2011, 12:33 PM
  #2624
NiMo's Avatar
If it is tipping over the front wheel you could try a slightly thicker front oil or (as I run) the thicker black front roll bar.
NiMo is offline
Old 04-08-2011, 04:56 PM
  #2625
mr fit's Avatar
You can use the short arms, just add 1mm washer against the pivot block to retail the same overall width.
thanks...
mr fit is offline
