Like Tree6Likes
Schumacher Mi4
Old 03-02-2011, 06:23 AM
  #2536
This sounds like the good old 'over ride height' or 'on blocks' confusion...
We are currently running CX's indoors on carpet at our club and I am running 5mm front, 4mm rear droop measured on blocks. But as always it depends on the amount of grip you have.
Chris Grainger talks about it around the 8/9minute mark in the video below;
http://www.youtube.com/watch?v=J-StH...layer_embedded
scoyle is offline
Old 03-06-2011, 05:28 PM
  #2537
scott_g's Avatar
Couple of weeks later than I hoped, but full build and drive test of the Mi4CX now posted at Action R/C.
Build story here
Drive story here
Cheers
scott
scott_g is offline
Old 03-07-2011, 02:05 AM
  #2538
CA
Nice work Scott!
CA is offline
Old 03-07-2011, 08:41 PM
  #2539
I'll be curious to see what you think of the big bore shocks.
-Mike
grippgoat is offline
Old 03-08-2011, 10:15 PM
  #2540
scott_g's Avatar
-Mike
I'm looking forward to trying them.
scott_g is offline
Old 03-09-2011, 10:09 AM
  #2541
Anyone know how much extra weight they put on the car?
YZFAndy is offline
Old 03-09-2011, 10:57 AM
  #2542
qcrc's Avatar
It depends on what parts and electronics you have. Also it depends on if you are trying to make weight or if you want it to be balanced too. I had to add 42g to make weight and get it balanced. I just checked it after changing tires and now I have to add another 40g to make weight.
qcrc is offline
Old 03-09-2011, 11:31 AM
  #2543
You misunderstand my question. I wanted to know how much extra, over the standard shocks, the big bores weigh? They look substantially chunkier.
Also i see on the big bores that the springs reduced in diameter towards the bottom of the shock to fit everything; does this mean the springs are progressive?
YZFAndy is offline
Old 03-09-2011, 04:51 PM
  #2544
qcrc's Avatar
Sorry Andy, I misunderstood too.
qcrc is offline
Old 03-09-2011, 07:52 PM
  #2545
Dusttt's Avatar
Trader Rating: 139 (100%+)
Big Bores question
Does anyone know if there is anything in the package besides the two assembled shocks? They are advertising them as working for other cars so I am hoping they would come with the bushings too.
Dusttt is offline
Old 03-09-2011, 11:45 PM
  #2546
lochness42's Avatar
Originally Posted by Dusttt View Post
Big Bores question
Nope, they are just assembled without any fitment stuff. So you have to get them separately.
lochness42 is offline
Old 03-10-2011, 08:20 AM
  #2547
CA
From memory I think its around 20g heavier.
CA is offline
Old 03-10-2011, 09:42 AM
  #2548
jrxs-r's Avatar
Hey everyone....
I have a slight problem that I am trying to sort out. I have been chewing through rear belts in boosted Mod with the standard black belts running high diff position tensioned 1 notch tighter than stock setting. It is getting quite frustrating as everytime a belt gets lunched, it takes out the center drive pulley and rounds off a bit on the diff pulley.
For those that run Mod, what kind of life span do you get out of the rear belt, and/or is there another belt which I can use to better the reliability?
Thanks in advance!
jrxs-r is offline
Old 03-10-2011, 12:11 PM
  #2549
Originally Posted by jrxs-r View Post
Hey everyone....
Thanks in advance!
Zack,
In modified racing, I've had no problems racing 6 months with a rear belt. I usually replace them after 5-6 months or when they show signs of wear. Make sure the belt isn't rubbing anywhere. And also don't over-tighten your belts. After only a couple of months I have to tighten them up a notch on the eccentrics. Usually I start on the middle position or one notch looser.
Rgds,
Jonathan.
Jonathan P. is offline
Old 03-11-2011, 05:24 AM
  #2550
jrxs-r's Avatar
Originally Posted by Jonathan P. View Post
Zack,
Rgds,
Jonathan.
Jonathan,
Thanks for your reply. I will try running them on the normal settings first and tighten up as we go. The belts are not fraying or wearing abnormally, so I am hoping that it might just be dirt ingestion that is causing it. Will update as time goes.
Thanks again.
jrxs-r is offline
