Like Tree6Likes
Schumacher Mi4
Old 06-04-2009, 10:03 AM
  #226
Originally Posted by José Cordeiro View Post
So, Mr. Silva, should be built by now, correct? Tell us your impressions...
Cheers,
eheheheh I wish... I wish...
Yesterday I've mounted everything except the rear sway bar and the shocks (still missing the electronic...).
What I liked:
1- Great step by step labels on each bag linking the manual step to the bags.
2- Love the motor mount. Just wonderful.
3- The sway bars mounting is a lot better now. Now I can mount then with almost no gap or undesired movement.
4- Awesome top deck and bulkheads. The small carbon links between rear bulkheads seems a great idea.
5- Very good camber link ball connectors support, made of thick carbon.
6- The stock ball cups are now great! No need to go for RPM ones. Really good fit with no binding with the balls.
7- The hex wheels are thicker which allows a better contact with the wheel mount and doesn't required the use of washers anymore.
8- One more hole in the shock towers for a better adjustment.
9- A lot better diff pulley, which I believe will make the diffs to last much longer.
What could be improved:
1- The holes in the suspension wishbones are a little too tighter for the bars that support them. I needed to use a dremel a lot to find a perfect fit.
2- Wasted a lot of time with the dremel to enlarge the screw holes at the bottom of the chassis. Otherwise they would make the chassis not flat.
And for now it's about it I'll keep you posted.
hhsilva is offline
Old 06-04-2009, 01:19 PM
  #227
Verndog's Avatar
Trader Rating: 16 (100%+)
So the pattern drilled into the chassis doesn't quite match the bulkheads, or mostly they just made the holes too small (body bound bolt to chassis)??
I would think you could just upsize the drilled holes a bit with larger drill, faster then dremeling...no?
Verndog is offline
Old 06-04-2009, 01:59 PM
  #228
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by abailey21 View Post
I haven't seen of heard that, hence my question to you
Guess we shall ask someone with a car?
What I liked:
Did the sway bars come with the kit? Or were they separate?
And pics!!
BlackedOutREVO is offline
Old 06-04-2009, 03:39 PM
  #229
And pics!!
Yes, they do come with the car!
Mr. Silva, glad you're enjoying the build. Keep us posted!
Cheers,
José Cordeiro is offline
Old 06-04-2009, 04:14 PM
  #230
The holes are fine. The issue is the fit of the screw head in the chassis hole underneath. If with don't enlarge the screw head socket in the chassis the screw head won't fit correctly. This normally happens with most of the cars, I think.
hhsilva is offline
Old 06-04-2009, 04:16 PM
  #231
And pics!!
The car comes with 1.4mm sway bars (front, rear).
Pics during the wekkend No time until then...
hhsilva is offline
Old 06-04-2009, 05:43 PM
  #232
skypilot's Avatar
Trader Rating: 14 (100%+)
sounds like he is saying the counter sunk part of the screw hole is what he enlarged so the screw would go deeper in the chassis plate
skypilot is offline
Old 06-04-2009, 06:12 PM
  #233
Verndog's Avatar
Makes sence. So you would need an 82 deg. countersink to make a fast / clean job of that. If you need one...let me know...or in a pinch you could match grind that on the end of a larger old drill bit.
Verndog is offline
Old 06-04-2009, 06:29 PM
  #234
Thanks Verndog, I got the job done
This Saturday I'll fit the electronics and setup the car. Pics by then
hhsilva is offline
Old 06-04-2009, 11:54 PM
  #235
Drifting101's Avatar
My Mi4, Yes I know camber,toe, droop or ride height is is not done. Still need to seal the chassis too because I am in the middle of exams lol-BTW also got alloy servo mounts...........Let me know if any one needs a certain angle
Drifting101 is offline
Old 06-05-2009, 07:29 AM
  #236
seaball's Avatar
aren't m3 screw heads tapered at 90*? or is this an anomaly?
File Type: pdf
seaball is offline
Old 06-05-2009, 08:52 AM
  #237
Verndog's Avatar
Interesting find. Generally a flathead is 82 degs. (at least in SAE), and the M3 stainless RC screws I just checked since this had me wondering measure pretty close to that. One easy way to check if your opening the counterbores is...use a felt pen and mark the screw head where it seats, insert into hole you opened up and using the ball driver push and turn to rub off the felt pen, remove screw and look for full contact.
This could seem a bit anal to some but imagine the screw head only contacting near head, then what an impact may do to shift and hold tweak.
http://www.mcfeelys.com/tech/dimensions.htm
Verndog is offline
Old 06-05-2009, 09:24 AM
  #238
seaball's Avatar
your 100% right on tweak. i mentioned it for just that reason. if the angles don't match, the bulkheads will move around much easier.
sae is 82*, but sedans using sae fasteners are pretty much extinct. i think 90* is the standard countersink angle for metric fasteners under something like m20. i am not 100% certain, but i've not found any information to contradict this.
while, on the surface it sounds a bit meticulous, all it takes is for one guy to redo his chassis at 82* to cause a bunch of bad press. (not to mention the troubles he might have fixing the issue).
the better solution might be to find some shallower screws, just for the lower chassis. the stuff that ships with the kit is a bit bulky. for what it's worth, the take-off steel screws that schumacher imports are simply stout. they are really low, and might even be a class 12.9. the socket fits well too. (two packets of TS-953 should get it done).
seaball is offline
Old 06-05-2009, 03:37 PM
  #239
Mike Haynes's Avatar
I had used an 82 on mine and havnt had a problem. Yes i thin m3 is really 90, but i make stuff uber tight so it wont shift either way...
Mike Haynes is offline
Old 06-06-2009, 03:10 AM
  #240
You have to be very careful countersinking the chassis. All of the holes are in the region that is pocket milled on the other side. So this means that you only have 2mm to play with - and 2mm is the "official" depth that you need to countersink to for an M3 head. What i'm trying to say is if you countersink to the "correct" depth, you could end up with a hole that is bigger than 3mm, and risk a screw pulling through.
Also, make sure you have a very sharp bit, because if not i think you could break the carbon layers up, as you are effectively pushing on air - as the pocketed side isn't in contact with anything.
Oh, and yeah, I would use a bit with the correct angle on it.
MattW is offline
