Schumacher Mi4
#1819
#1826
Don't get me wrong Schumacher car is awesome just a little sensitive on different track surface. The chassis balance of the E4 makes it really easy to drive specially on MOD. If you guys haven't drive one you guys will be surprise how the car transition left to right specially on a swipper and high speed corners.
Owen,
I will send my E4 to you to be blacked out....
Owen,
#1827
Owen,
Owen,
#1828
Both cars are setup a little different, what is similar is the shock oil/pistons, both are running like 50/40 with 3 hole pistons. The rubber car had blue springs up front, white rear, the rcgt had white/hpi silver. Rubber car has short front Med arms, long rear med, stiff chassis, soft top deck, the RCGT has long c/f arms all around, noodle FRP chassis with thick top deck. Rubber car has front gold sway bar only, rcgt car had none. The pins were level, 1mm roll center front, 2mm rear, about 3dg rear toe, 1dg front sweep, etc.
It didn't sound like the front was scraping on the ground under braking, which I know can unsettle it, I feel like it need to transfer some more weight so it unloads the rear and it drifts around abit, the cars were both pretty planted.
#1830
http://www.youtube.com/watch?v=O3mxKV1sNZs
Here is a vid of the last qual, to me it looks like the car doesn't rotate mid corner enough, I'm sure part of it is driving
and well sorry whoever that was that I plowed in the sweeper, but apparently they brake more than I do
The car was getting tippy this run which is why I flipped anytime I hit the curbs..
