Like Tree6Likes
Schumacher Mi4
Old 04-12-2010, 12:30 PM
  #1786
Kenny L's Avatar
Trader Rating: 16 (100%+)
Originally Posted by SRW141
You can buy directly from Schumacher in the UK. at www.racing-cars.com
I second that. I get my orders usually in three days
Kenny L is offline
Old 04-12-2010, 01:56 PM
  #1787
Kenny L's Avatar
Also running long rear arms
Kenny L is offline
Old 04-12-2010, 01:59 PM
  #1788
Trader Rating: 15 (100%+)
What type of spurs can i fit on this bad boy? Mine came with a 118T spur, I dont have any other styles like it came with and I didnt want to purchase a bulk amount if they wont fit
Double D Donuts is offline
Old 04-12-2010, 02:00 PM
  #1789
Kenny L's Avatar
Either Schumacher direct or Rw gears work great
Kenny L is offline
Old 04-12-2010, 02:15 PM
  #1790
much appreciated!!
Old 04-14-2010, 03:33 PM
  #1791
Kenny L's Avatar
After looking at sheet again noticed typo shimming in front is backwards on my sheet should be swept arms
Kenny L is offline
Old 04-16-2010, 11:49 PM
  #1792
Dusttt's Avatar
Trader Rating: 144 (100%+)
I see in the set up sheet in the back of the manual it says the doop is measured while on a 10 mm block. What point are you guys meauring from with this car? The bottom outside of the wish bone?
Dusttt is offline
Old 04-17-2010, 11:25 AM
  #1793
I measure under the rear hub carrier and under the front castor block.
SRW141 is offline
Old 04-19-2010, 06:43 AM
  #1794
I ran my Mi4 for the first time outdoors yesterday (and first time really overall)
Car was very twitchy, handled awful. I was loosing over a second per lap on the top 10 , by the end of the day noly .5 seconds per lap.
I started with one of the Brit team drivers setups (C Grainger / West London).
I have attached my setup sheet to have a look at to, this is the final setup I ended up on.
The car itself just had no real turn in, drifted and pushed out bad on power, would turn in sharp off power and then the backend would go loose.
I was tempted to put harder springs on the front, but not sure if this would have only made things worse heating the front up further, so making the car push even more.
Any advice is welcomed
Jo90uk is offline
Old 04-19-2010, 07:16 AM
  #1795
It sounds like the rear of the car is stuck. I have found laying down the rear shocks frees the rear up and lets it rotate the corner.
SRW141 is offline
Old 04-19-2010, 08:11 AM
  #1796
Dusttt's Avatar
Thanks! Thats prettty much what I did. I need a good set up for a high speed high traction track (West Coast) and a setup for a low traction parking lot if ayone has one.Both are asphalt. I have the mi4LP pro
Dusttt is offline
Old 04-19-2010, 08:50 AM
  #1797
Is anyone running Sweep on the front of the car? if so how much and why did you put this sweep on?
main reason i ask, is I am struggling with getting the car to enter the corner quicker - its like trying to turn a bus. Corner exit is lovely, but entry is just very slow.
Will some sweep help get a bit more entry?
geubes is offline
Old 04-19-2010, 08:51 AM
  #1798
Send me a PM with your email address and I will send you a setup for low bit. After this weekeend I will have one for medium bit. I tried to attach to this but it was too big.
SRW141 is offline
Old 04-19-2010, 09:15 AM
  #1799
mickrcarver's Avatar
Trader Rating: 101 (100%+)
Hey can I get those setups also? it would be greatly appreciated
[email protected]
mickrcarver is offline
Old 04-19-2010, 09:39 AM
  #1800
First time outside this year:
+ YouTube Video
andy3000 is offline
