Like Tree6Likes
Schumacher Mi4
Old 03-06-2010, 05:54 PM
  #1681
Jochim_18's Avatar
HPI Pro Spring all the way they got better feel....
Jochim_18 is offline
Old 03-08-2010, 11:04 AM
  #1682
Psql's Avatar
You then use the HPI 75175 Pro 4 spring set?
Psql is offline
Old 03-08-2010, 11:14 AM
  #1683
Yes, it work fine, the unique dissapoint is the litle paint is delete in a few races, you need to paint it.
Greetings, Luis C.
luic is offline
Old 03-09-2010, 01:06 AM
  #1684
Graham Kenny's Avatar
Anyone wanna trade a set of XRAY springs 2.4,2.6,2.8,3.0,3.2,3.4 for a full set of Mint HPI springs, Pinks,reds,blues,white,gold,silver ect ect
Graham Kenny is offline
Old 03-10-2010, 11:50 PM
  #1685
So tonight I made it about 3 laps before the left rear fell off the car. I didn't think I hit anything very hard. It could have been from someone t-boning me on the straight after I spun out. Anyway, one of the screws holding the pivot block sheared off, and then it bent the hinge pin, and bent a camber link turnbuckle.
1) Are the titanium hinge pins stronger than the regular ones, or just lighter? They're only $13 as opposed to $9 for the regular, so if they're stronger, it's worth the money.
2) If I go from the CF arms to the med flex arms, will the car be more durable? I'm getting really frustrated breaking things all the time.
-Mike
grippgoat is offline
Old 03-11-2010, 01:45 AM
  #1686
1) No, the Ti pins are not stronger, just lighter. If anything, they bend easier than the steel ones.
2) Med flex arms are a bit more durable, but they also change the handling of the car. No point in using the med ones, if the car doesn't handle well with them. In low-med grip conditions the car might be better with med arms, but on high grip carpet, CF is the way to go.
olev is offline
Old 03-11-2010, 06:46 AM
  #1687
Jochim_18's Avatar
Avoid hitting the boards I hardly break anything but if I do I usually destroy the car....
-Mike
Old 03-11-2010, 06:51 AM
  #1688
Jochim_18's Avatar
I got my MI4LP yesterday... I got a little problem when I was putting the diff and front spool together last night and the Sidewall Ring and goes on the diff and spool don't fit..... So I have to use the diff and spool on my spare MI3.....
Anyone of you guys have this issue???
Old 03-11-2010, 07:11 AM
  #1689
seaball's Avatar
they fit tightly. you can boil them to heat the plastic if you need extra assistance in getting the rings over the pulley flange. i rather this, than have them coming off in a run, and letting the belt fly off.
seaball is offline
Old 03-11-2010, 07:16 AM
  #1690
MikeXray's Avatar
Trader Rating: 73 (100%+)
-Mike
I'm going to have to say that in order to shear off a screw that tbone must have done some damage! I've bent plenty, but never broken one.. Any chance you have some axle threads sticking out past your wheel nuts? this can catch on the boards and make a big mess out of "light" taps.
MikeXray is offline
Old 03-11-2010, 07:39 AM
  #1691
steveonamission's Avatar
They do fit, but are extremly tight.....i had to stretch mine a tad, no biggy.
steveonamission is offline
Old 03-11-2010, 07:49 AM
  #1692
Jochim_18's Avatar
Ok I'll try it again I tried stretching the damn thing it's just way to tight they got more material than it should I think...
Old 03-11-2010, 07:50 AM
  #1693
Jochim_18's Avatar
I was putting it together late last night I just don't have the patience I guess..
Old 03-11-2010, 07:55 AM
  #1694
mike and Alex's Avatar
put the side wall's in hot water for a minute then clip them on.
Regards,
mike and Alex is offline
Old 03-11-2010, 09:01 AM
  #1695
Jochim_18's Avatar
Clip them how? I was thinking of just sanding them enough to fit snugly then just CA them on the pulleys...
Regards,
