Old 02-05-2002, 05:58 AM   #1
sonneteer's Avatar
Cool Stock Motor Survey!!!
I thought I join the survey bandwagon.....
I like to know your favourite stock motors.... and why.... like:
Motor: whatever make
For: revs like hell
Against: no torque!!!
Remark: Good on long tracks with long straights and not much infield...
Rebuilds: often / not often etc...
I am only talking about straight out of the packet ones, but you can also recommend any simple upgrades like changing brushes or springs to improve its performance.... we can call it
Best Upgrade:
If you dont want to give the game away then we can leave that out...
Of course you can mention several of them.... I just like to find out more on the general characteristics of what is available out there....
sonneteer is offline   Reply With Quote
Old 02-05-2002, 06:05 AM   #2
sosidge's Avatar
Motor - trinity p2k.
only mod - integy x-pattern 4%silver brushes - these brushes improved punch a lot.
Characteristics - people at one club think I'm running a mod (occasionally) (but at another club i get blown away).
Old 02-05-2002, 08:53 AM   #3
Motor - GM3
Brushes - Orion pro stock
springs - red / green
Brushes make a big difference to performance over standard brushes.
Keeps up with Sosidge down the straight and very punchy on the infield: sneaky:
Trying out a Reedy Rage this week fitted with Reedy 768 brushes, Trinity red / green springs.
Let you know how this compares.
Yorkie
Yorkie is offline   Reply With Quote
Old 02-05-2002, 10:27 AM   #4
Trips's Avatar
Trader Rating: 16 (100%+)
Motor: Trinity Green Machine 3
For: really revs
Against: they're said to go up in smoke more than others
Remark: great stock motor
Rebuilds: every race day
Best Upgrade: Reedy 767 brushes, trinity red spring on + green on -
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 02-05-2002, 11:00 AM   #5
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i like the trinity gm3....i use reedy 766 brushes, with a cavity, and i use either green or red springs, depending on the track layout....
Matt M. is offline   Reply With Quote
Old 02-05-2002, 11:05 AM   #6
I have 2 favs.
P2K2
4499 Trinity Brushes
Purple/red springs
MVP
.140 4499 Trinity Brushes, like them better than the 766.
Red/Green or Purple/Red springs depending on track
At the moment the P2K2 is the faster motor of the two.
bmxxxry is offline   Reply With Quote
Old 02-05-2002, 01:27 PM   #7
Right now I'm running a P2K2, 767 brushes, red/green springs. It's good down the straights, but a little soft out of the corners.
I like the P2K, P2K2, MVP, GM3, but each one at a different time.
JeffC is offline   Reply With Quote
Old 02-05-2002, 01:30 PM   #8
Can anyone tell me what the different spring rates are for the brushes i.e softest to hardest.
What effect does running stiffer or softer springs on the + or - sides?
Yorkie
Old 02-05-2002, 02:37 PM   #9
sonneteer's Avatar
Trips.... do you lathe your comm at every race? how many runs do you get between each cut?
Currently I am using 2 motors, a standard P2K Pro and BRM stock... I am trying new brushes on the P2KPro soon. The BRM is a very torquey motor and it really starts to shine after having 2 packs thru it.... but I find the hard silver (180 degrees or so ) springs maybe a little tough on the comm, so I am trying to use RED/GREEN combo or Purple springs and see if it makes it any different...
Old 02-05-2002, 02:44 PM   #10
fatdoggy's Avatar
R/C Tech Charter Subscriber
Yorkie
I think this is right but am not sure. Hard springs give the motor more torque and soft ones give more rpm. I think. Don't trust me to this .
fatdoggy is offline   Reply With Quote
Old 02-05-2002, 02:48 PM   #11
sonneteer's Avatar
Yorkie... On the Team Orion site they have a range of springs which are listed in degrees.... the wider, the stronger... much easier then remembering colours...
WIth Trinity... I only know green is softer than red which is softer than purple, the hardest I will go except for the one cam with my BRM....
From what I have gathered.... the tighter the spring, you get less RPM but more torque... but either too light or hard you will get more comm wear....Light springs = more bounce and hard springs = more grind!!! can't win.....
Old 02-05-2002, 04:53 PM   #12
Thanks Guys,
That's a great help. I'm getting to the stage where I can tell a big diference between different brush an spring combos.
I looks like red / green springs are the favourite and brushes seem to be down to personal choice.
Yorkie
Old 02-06-2002, 01:43 AM   #13
Trips's Avatar
Stock or mod, I cut my comms at least after every race day, and if theres enough time between rounds I might cut after two rounds.
I relpace the brushes if they look discolored or if they are getting short. Otherwise I just clean them up and re-serrate and break them in again.
Trips
MARSHAL!!
Old 02-06-2002, 05:18 PM   #14
sonneteer's Avatar
Good advice Trips.... I have been trying a new motor and I had the third runs on my second to about sixth= seven run... and on my ninth and tenth run I noticed the motor feels a bit slower.... so I guess after runnind in I get max performance for about 4 runs before it starts to deteriorate....
Looks like i need to import a Team Orion laths as it seems no one got them here... and others are 40% more $$$
Old 02-07-2002, 08:07 AM   #15
benraldo the ho's Avatar
Send a message via AIM to benraldo the ho
Motor: P2k, black springs Trininty 4500 brushes
For: track spec motor, good balance of tourque and revs
Against: could rev a little higher I think
Remarks: good motor, I like spec class because it levels the playing feild
Rebulds: Whenever someone I know whips out thier comm lathe...
benraldo the ho is offline   Reply With Quote
23T stock motor is equal to which brushless motor ioxqq Electric On-Road 9 11-04-2013 08:19 PM
Stock Motor Lot w/Trinity case and Much More Motor Mate Racer4Life R/C Items: For Sale/Trade 2 08-19-2007 09:04 PM
Method to run-in stock to higher turm motor? or a stock tune to a higher turns? micro80 Malaysian R/C Racers 0 06-16-2007 12:40 PM
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 11:22 PM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
