Old 04-23-2011, 09:33 AM   #1471
Default Spacer ??
Hi Jilles,
what does it mine if u only type 2mm spacer in front of the frontarm?
is there suppose to be 0 mm in the back then?
Thinking off your basic outdoor rubber setup?
Cp Grafix is offline   Reply With Quote
Old 04-23-2011, 09:31 PM   #1472
AWK
AWK's Avatar
Jilles,
How do you maintain the bearings on your cars? How do you clean them in between races? How long do you feel they last?
Good luck this season!!!
AWK is offline   Reply With Quote
Old 04-24-2011, 05:18 AM   #1473
Jilles, on your snowbirds setup what would you change to achive more corner exit steering? thanks
franc furter is offline   Reply With Quote
Old 04-24-2011, 08:28 AM   #1474
JGH
Originally Posted by Cp Grafix View Post
Hi Jilles,
- Cp Grafix
2mm front and 2.5mm back, as total shims of the suspension arms is 4.5mm
Originally Posted by AWK View Post
Jilles,
- AWK
Honestly I never clean the bearings, I run them till they feel not good anymore and replace them. Some bearings I still use over 1 year already and still they are fine.
- Franc, to get more exit steering you can try arm sweep. Like 1C and 1B blocks. This gives more caster so more exit steering.
Originally Posted by The Big Wig View Post
What is the reason for that? On power grip, something else? Any circumpstace U still use a ball diff?
- Big Wig, the geardiff has zero slip, therefor you have more drive on the rear, then a balldiff. That's why geardiff has more steering on-power. All tracks I use geardiff in the rear now.
Originally Posted by WinDarK83 View Post
Hi Jilles, I understand, you use FF 0 mm and FR 0.5mm ?ŋ
Regards
- Win dark, correct!
Originally Posted by Jon-b View Post
Ok pefect !! Thank you very much that answered my question completly I'm gonna run it in the rear with 1000WT thanks again
- Jon, let me know how things went with your test/race
Jilles
JGH is offline   Reply With Quote
Old 04-24-2011, 08:51 AM   #1475
Hello Jilles, thanks for all your help, i donīt run a Tamiya car, but i follow this post because is very helpfull, Ronald help too, in yokomo post, and anothers top drivers, this is good for the hobby.
I have a litle problem, i think this is indiferent for a brand of car, with my setup normally my car work very good with new tyres, but the performance going down a lot with used tyres, sometimes in the 2nd battery, do you have a tip, change in setup, ... for the performance going down less, or do you think need 2 diferents setups for new-used tyres.
Thanks, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 04-24-2011, 08:52 AM   #1476
TryHard's Avatar
Hi Jilles,
Finally got to use my Sanwa handset today (it's been how many months since TITC!!), anyway, I have a question for you on how you set yours up.
I'm having to run 115% D/R (with EPA's at 100%R, 95%L) to get my desired amount of lock... does this sound right to you?
Regardless, have to say, feels so smooth to drive, and much lighter in the hands too, a BIG improvement
Cheers
Ed
| THard.co.uk | Xray | MuchMore |
Old 04-24-2011, 02:35 PM   #1477
Hi Jilles.
I am going to race asphalt for the first time (and I only recently switched to Tamiya) this outdoor season. I have seen some of your setup sheets, but those were for high traction asphalt. I am going to race at a large outdoor track, with low grip. What setup would you recommend?
// Niklas Hansen
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 04-25-2011, 10:28 PM   #1478
JGH
Thanks, Luis C.
Luis, no problem! Good to see Ronald is also active at RCTECH, this is something more topdrivers should do, I agree.
Most of the time new tyres are faster then older tyres. You can't do much about this. Sure you can change your set-up for new and used tyres and also additives. But you need a lot of tyres to really test this.
But I can recommend a thinner additive for new tyres and thicker additive for used tyres. Thin additve such as FX2 and thick such as Tyre Tweak.
Originally Posted by TryHard View Post
Hi Jilles,
Cheers
Ed
Hi Ed, good to hear you finally changed! I run my D-Rate at max.150% and EPA about 95% to get full lock.
Originally Posted by Nilks View Post
Hi Jilles.
// Niklas Hansen
Niklas, I'm sure the set-ups you have from one of the TRF drivers will be good enough for starting set-up. The Worlds set-up is probably the best set-up which also works for 417. As the worlds was run on medium grip tyres this set-up will work at medium grip track as well.
Other things you can try to get more traction is stand-up the shock little more, softer springs and softer oil.
Jilles
Old 04-25-2011, 10:36 PM   #1479
geeunit1014's Avatar
Jilles,
What was the main advantage of shimming up the bulkheads 0.5mm on the 416? Did you also put an extra 0.5mm under the arm mounts when doing this?
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 04-25-2011, 11:33 PM   #1480
TryHard's Avatar
Jilles
Thanks Jilles, I'll be turning it up the D/R next time then. A fair few locals say my cars always look like they understeer.. wonder if that's part the reason...
Old 04-27-2011, 04:52 AM   #1481
crabboy's Avatar
Trader Rating: 58 (98%+)
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 04-27-2011, 02:39 PM   #1482
Hi Jilles,
How are you ?
I would like to know what can we do if the tires are overheating ?
Harder shock oil ? Softer spring ?
Regards,
Manu
Manu_05' is offline   Reply With Quote
Old 04-27-2011, 10:27 PM   #1483
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
JGH,
Recently found a CRC setup for the worlds you used a Orion 3.5 but no rollout information..
Are you willing to share?
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
Old 04-28-2011, 01:47 AM   #1484
shikakae123's Avatar
Hello Jilles.
I want to ask,how does rebound on the shocks effect the car?Should there be alot of rebound or only a little?
shikakae123 is offline   Reply With Quote
Old 04-28-2011, 01:01 PM   #1485
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Is there a length you set your front and rear sway bar links ?
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
