Old 01-17-2011, 07:06 PM   #1381
JGH
- Chico1977
Don't worry, normally you not have to cut. I mean if the driveshaft is too close to the diff screw end you can cut a little bit of the screw.
- Eirik,
Last weekend I have tried running the shocks as you say.
It feels like little less traction, anyway I think when the traction comes up it's not so bad. I will keep on playing with this kind of stuff, thanks for the tips!
- b-man777
Same to you! I have tested the 417 for some time now and I found it faster.
All weight is more to the centerline for quicker response. I really like the one piece motormount, I haven't broke one spur yet even with 4.0T motor.
The motormount makes the car a lot more stable with hot motors as well.
I'm not planning to do much off-road but who knows, maybe in the near future!
- rccartips
Can't really tell you the differents. Just try out yourself and you will feel the difference. I should say the effect of changing the suspension height will do more then rollbar thickness.
- Oscar
I never go above 1000W as this feels the best on the track.
It is pretty thin and you need to refill the diff sometimes.
I quess with even thinner shockoil you need to refill every battery!
Thin oil always feels most stable so it's really not bad!
Two month ago my wife gave birth to a son, Valentino!
- Gerwin,
Thanks!
Maybe I will join the ETS in Apeldoorn, depends on my schedule.
I'm trying to post some set ups but I can't find a proper set-up sheet that you can post within the 480kb limit.
Maybe someone can help me with a set-up sheet for the 417 who I can upload easy in this thread?
Jilles
p.s. For those who are interested, I will attend the Snowbirds race next week!
JGH is offline   Reply With Quote
Old 01-17-2011, 07:31 PM   #1382
syndr0me's Avatar
Trader Rating: 32 (100%+)
This is great news!
syndr0me is offline   Reply With Quote
Old 01-18-2011, 12:10 AM   #1383
Good luck at the Snowbirds.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 01-18-2011, 12:17 AM   #1384
PizzaDude's Avatar
A lil birdy told me Jilles isn't going to attend...
@Jilles c email
PizzaDude is offline   Reply With Quote
Old 01-18-2011, 01:25 AM   #1385
TryHard's Avatar
Hi Jilles,
Tamiya Japan has a blank sheet up;
http://www.tamiya.com/japan/download...f417_blank.pdf
I'm sure there was interactive pdf one as well somewhere...
EDIT - found it over at Petit RC
http://www.petitrc.com/reglages/tami...SetupSheet.pdf
Good luck at the snowbirds.
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-19-2011, 11:24 AM   #1386
Hi Jilles,
Do you know these spec-r shock towers for 416?
Any idea whats the benefit of them?
jorgesimes is offline   Reply With Quote
Old 01-19-2011, 02:45 PM   #1387
Trader Rating: 19 (100%+)
Good luck at snowbird Jilles, it would be cool if you would maybe post your setup of your car after if thats not a problem.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 01-19-2011, 08:10 PM   #1388
KHoff7's Avatar
Are you going?
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 01-20-2011, 12:59 AM   #1389
PizzaDude's Avatar
Originally Posted by KHoff7 View Post
Are you going?
I stand orrected
Jilles will be off to the birds.
Old 01-20-2011, 09:51 AM   #1390
When using wheel spacers (ie 0.5mm on the hex) what does this do?? going wider than 0.5mm would it give you more or less grip at that end of the car??
Smartypants is offline   Reply With Quote
Old 01-20-2011, 10:52 PM   #1391
guinnes.s's Avatar
i need some help Mr Jilles
im racing the old 416 and cant get it to dive into the corners.
it "push on power".
if i approach the corner quite slow is ok but when i increase speed the car push making the turn quite wide.
steering is at 100%
i include my setup in hope u can give some suggestions
thanx
http://dl.dropbox.com/u/14415603/my%20setup.PDF
guinnes.s is offline   Reply With Quote
Old 01-29-2011, 02:30 AM   #1392
Jack2's Avatar
Default setups
Hi Jilles, Any setups as yet for the 417?
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 01-29-2011, 03:41 AM   #1393
Eirik's Avatar
[QUOTE=JGH;8503875]
- Eirik,
QUOTE]
Hi Jilles,
Yes, Initial traction will be a little less, but I have found it to give more cornerspeed and it changes direction faster, especially with Sorex tires and good traction tracks.
Good luck at the Birds, bring home some trophies ;o)
Eirik
Eirik is offline   Reply With Quote
Old 01-30-2011, 12:51 PM   #1394
Congratulations on taking the TQ and win in Mod TC @ Snowbirds. Looks like you have a firm grip on that 417!
Kody is offline   Reply With Quote
Old 01-30-2011, 05:37 PM   #1395
- Oscar
first of all, congrats. with your first place at the snowbirds and the birth of your son!
i have one question about the oil in the geardiff, is it ok if i use Tamiya 1000W shockoil in a geardiff?? or did i understand your answer wrong?
thnx
TamiyaRC is offline   Reply With Quote
