Old 12-21-2010, 01:53 AM   #1366
Hello Jilles,
congratulation to your Child, can you sleep?
My Children are 12 an 16, i can sleep
Have you a Besic Setup for 417 for me?
kiloolli is offline   Reply With Quote
Old 12-21-2010, 01:22 PM   #1367
20967's Avatar
Congratulations for the birth of the child. I wish you Merry Christmas and Happy New Year.
Enrico from Italy
20967 is offline   Reply With Quote
Old 12-26-2010, 09:17 AM   #1368
Hello Jilles .
I have a question.
I drive the tamiya 416 we with smokem chassis FX.
And I have always ne-less Rear.
Does it perhaps together with the Droopstop aways
Drive front 6mm and rear 5mm.
Vehical height is 5mm Fornt and Rear5,5mm.
Front Springs Tamiya white Rear Tamiya blue.
Oil damper 400 .
Camber Front 1,5 , rear 2 degree.
Rollcenter front 4mm 2mm behind.
Maybe you´re still a littel tip for me
I´m going to carpet .
We met at the World Cup in Burgdorf.
I think it´s cool that one can ask what do you here, keep it up
Greeting Stefan from germany.
need not be
stefan Köhler is offline   Reply With Quote
Old 12-26-2010, 04:44 PM   #1369
Default hello Jilles
hello Jilles
could you tell me a tune for very low grip track.
what steps you would take to go from standard tuning to a set-up for a track with little grip
asier is offline   Reply With Quote
Old 12-27-2010, 01:23 AM   #1370
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Had anyone used a Orion motor with a GM esc running version 13 of the software?
have a 5.5 and 4.5 in 12th scale any advice would be good
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
Old 12-27-2010, 01:29 AM   #1371
sickboy's Avatar
Trader Rating: 72 (100%+)
Originally Posted by Tron View Post
Where do you get the red foam to use on the shock bladder below the cap?
Tamiya p/n 53577
Tamiya America www.tamiyausa.com
Team TRF www.teamtrf.com
Pro-Line www.prolineracing.com
818Designs.net - TKO
sickboy is offline   Reply With Quote
Old 01-12-2011, 07:21 PM   #1372
JGH
Dear Racers,
Back to the thread! I have had some really good tests with the 417 over the last weeks. Later this week I will post some set-ups, first need to find a 417 set-up sheet!!
And to one of the moderators, can you change the thread name to:
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors
Back to your questions:
- Ed (Tryhard)
Nice you can make it to the TITC race, it's really awesome track and good facility! See you soon!
- Mugen10
If you use 1mm shims under the front suspension the car will become more smooth to drive, without shims it should behave more aggressive.
When running under cold surface I suggest soft tyres like Sorex 24R.
Also rim and insert should be soft.
- Hi Jonest
See you at TITC! Some of your buddies where at the Futuba Cup last week.
- Oli
Thanks for your message, sure see you somewhere soon!
- Chico1977
I always run 46mm and 44mm driveshaft.
This gives most traction. When running diff in the rear you might want to cut something from the diff screw.
- Hi Ed!
It has been very busy with the baby but a great new experience!
See you!
- srw_g
Thanks!
1. I never use any shim or spacer for rebound, I like to run my shocks with less rebound.
2. Difficult to answer this as I don't know the traction on your track.
Most of the time now I not go thicker then 600W with very soft spring like HPI Blue.
3.I can't tell you the differents between 2 and 3 holes, what I do know is that 3 holes always works better then 2 holes!
- Luis C
Thanks!
Changing diapers is getting faster now!
- Eirik
Your comment makes a lot of sense.
However we never use any foam to increase rebound on big events. We always feel zero rebound has most traction.
The track you tested this is flat or bumpy?
- Ciro
In Apeldoorn (ETS 2009) I used 0.5mm and 0.5mm suspension spacers.
- Kiloolli
Thanks!
Will post basic set-up later this week.
- Enrico
Thanks! Same to you! ( little late)
- Stefan
I think the smokem chassis is good on high grip track but not at all tracks.
Further I should need more info about surface, tyres and set-up to know why the rear is loose?
- asier
Normally on low grip tracks first find the best tyre/additive combination.
What you can try is to make more flex in the car, like cut the topdeck in the centerline. Shocks more vertical also helps with slightly softer oil and spring.
Set-ups 417 coming soon!!
Jilles
JGH is offline   Reply With Quote
Old 01-12-2011, 08:13 PM   #1373
CHICO1977's Avatar
what is it i have to cut? is it the same thing i have to do on the 417? thanks see you at TITC
CHICO1977 is offline   Reply With Quote
Old 01-12-2011, 11:34 PM   #1374
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Hi Jilles! See you at TITC! How's the testing at RC City going? Sent you a message the other day as well but will ask here too ... what body would you suggest for RC City? Is the LTC-R the body of choice? Also, what compound works best? Hope you can help us out with tire prep ... getting there really late on the 23rd as mentioned so will have very limited practice time
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 01-13-2011, 11:55 AM   #1375
Eirik's Avatar
Originally Posted by JGH View Post
Eirik
Jilles
Jilles,,
I still have close to zero rebound with the foam on top of the bladder, it is just supporting the bladder.
It takes a litlle more time to make them perfect, but no big deal really.
Very important that you cut them to 3mm.
The track is normal, small bumps here and there, medium to high traction.
You really should give it a try, I am sure you will like the cornerspeed it generates. And, check out your laptimes ;o)
Later mate,
Eirik
Eirik is offline   Reply With Quote
Old 01-13-2011, 01:36 PM   #1376
CraigM's Avatar
Trader Rating: 34 (100%+)
Try the new xray foams, they are about that height
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-13-2011, 03:07 PM   #1377
b-man777's Avatar
Hey Jilles: Happy new year and all the best in 2011. First I'd like to know if you've driven the new TRF 417 sedan yet and what makes it better and or different than the TRF 416 series? Second do you plan on doing any electric off road racing with the ifmar off road electric worlds coming in 2011? thanks for the info
b-man777 is offline   Reply With Quote
Old 01-13-2011, 05:35 PM   #1378
Hi Jilles,
For controlling roll, what's the difference between spacers under the suspension blocks versus anti-roll bars?
Thanks in advance.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 01-14-2011, 08:56 AM   #1379
OscarF1's Avatar
I use 1000W oil in the gear diff.
JIlles
Hello Jilles,
I am new with the geardiffs,
first I build it with 2000 oil which came along with it.
But when I was ready it felt too greasy.
So I filled it with shock oil.
For my son and me it works perfectly.
What could/will happen when the oil is too thin?
Did you try that yet?
Are you a DAD now? (girl? boy? twins?)
OscarF1 is offline   Reply With Quote
Old 01-17-2011, 11:09 AM   #1380
Hello Jilles,
Gefeliciteerd met de baby!
You might come to ets Apeldoorn This year?
Thanks already for plating THE trf 417 setups.
Gr. Gerwin
GerwinGood is offline   Reply With Quote
