Old 09-15-2010, 01:59 AM   #1276
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Jilles,
thanks for dropping by manila and sharing some time with the local racers. hope you had as much fun as we did.
Jason
something to remember us by... (Jilles whipping everybody's butt running 13.5BL)
http://www.youtube.com/watch?v=LLGzU4eZnFM
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 09-15-2010, 02:29 AM   #1277
Glorykid's Avatar
What gear ratio was he running there???
Nemo Racing~Agama~Bullitt~Beta~Piranha~Racer
Glorykid is offline   Reply With Quote
Old 09-15-2010, 03:25 AM   #1278
Hi Jilles,
Hope you enjoyed your stay in Manila. Thanks for racing with my daughter (pink M05). I'm sure she will remember it for a very long time.
Joel
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 09-15-2010, 06:46 AM   #1279
xray09ACT's Avatar
kudos to you Jilles. It is great to see the top world class guys race with club guy and actually allow them to catch you and learn from you instead of just running away from everyone. For me this is what makes a good champion.
ACE Hobby Australia | Monaro models
TEAM Associated TC6 | LRP | LRP
TEAM Associated TC6 | Nosram | Nosram
TEAM Associated 12R5.1 | LRP | LRP
xray09ACT is offline   Reply With Quote
Old 09-19-2010, 02:58 AM   #1280
JGH
Hello racers,
Sorry for not being around lately. Need to go back some pages to answer you guys!
- CraigM
Set-up from Worlds is posted, I don't have a set-up from the ETS at Heemstede, but it's similair to like Euros 2009 set-up while the track is highspeed.
- srw_g
Differents between 1C/1C and 1B/1D:
1C/1C give more steering entree corner, 1B/1D more steering middle corner or sweeper. I prefer 1C/1C most of the time.
- hansonhan
Marc uses SMC batteries, Viktor and Elliott Speedpower and I use TeamOrion 5400 Lipo's.
- sidecarphil
Thanks for your message. Frank is doing fine now but is not 100% recovered yet.
-alcyon
I never use the urethane foam as this gives more rebound and I prefer zero or very little rebound at all times. The thicker the oil the slower the damper go out again.
To reduce the rebound the hole in the cap helps a lot, 1mm in enough for the hole.
Always find compromise between hard and soft spring as sure you have more roll with softspring. Harder rollbar in combination with softspring works very well.
- Pinion King
Please give me more info about set-up, tyres etc.
- transplantlife
For the new lipo chassis you not need to change the set-up. Both Snowbirds and LRP masters set-ups will work fine.
-Tamiya RC
I haven't been racing in the rain so much but some changes you can make are:
- droop, little more uptravel, less droop
- softer spring, oil
- ride height little higher, this also effects the droop number
10.5T is very fast these days so no need different set-up compare to modified.
-Chris
At Worlds and Snowbirds I used Ko Propo 2367 servo, is very strong and fast enough.
- Jason
Thanks for posting the video, really cool. I really enjoyed the race on wednesday night!
- Glorykid
I used 5.5 ratio with 13.5T Orion Vortex and LRP stock spec speedo power program 6.
- Joel
It was really nice to race with Porsha, she is a real talent!
- xray009Act
Was nice third final with Gerry, it's better to race close together then race your own race.
Till next time!!
JGH is offline   Reply With Quote
Old 09-19-2010, 03:50 AM   #1281
CraigM's Avatar
Trader Rating: 34 (100%+)
Thanks for that Jilles, with the worlds setup why did you guys run 1mm lower inside camber links compared with usual?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-19-2010, 01:21 PM   #1282
Glorykid's Avatar
Thanks Jiles, im using your snowbird setup but with a gear diff with 2000wt oil, car is so nice to drive, may go up to 3k
Old 09-19-2010, 07:45 PM   #1283
JGH
- CraigM
At the Worlds we used less shims as we needed more aggressive steering.
The track was tight and narrow that was the main reason.
- Glorykid
I haven't tested the geardiff on carpet yet, but I quess it works fine too!
Jilles
Old 09-20-2010, 01:54 AM   #1284
jonest's Avatar
Hi Jilles,
Glad to hear that Frank is recovering...
Just check with you, what's your setting using the latest Nosram / LRP speedo (SXX v2) for 4.0t and 4.5t motors? Is there any difference between Much More shock oil and Tamiya's VG shock oil?
Thanks and hope to see you at TITC 2011.
jonest is offline   Reply With Quote
Old 09-20-2010, 02:33 AM   #1285
Hi Jilles,
I wonder if you TRF teamdrivers have already had your hands on the new TRF417? (or maybe just on parts of it?)
What do you guess will it improve compared to the TRF416x (incl. Lipo Chassis)? Is it worth waiting for the TRF417 instead of simply buying a TRF416 Lipo Chassis?
regards, Oliver
Shqizy is offline   Reply With Quote
Old 09-20-2010, 02:45 AM   #1286
nitro rat's Avatar
Trader Rating: 5 (86%+)
Originally Posted by Shqizy View Post
Hi Jilles,
regards, Oliver
+1
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
nitro rat is offline   Reply With Quote
Old 09-20-2010, 03:32 AM   #1287
jills~
Have you use the LRP/nosram sxx ver.2 esc now..??
can you share your setting about he feel and boost....?
thanks!!
teamsanwa is offline   Reply With Quote
Old 09-20-2010, 08:09 AM   #1288
JGH
- Jonest
Honestly I still use "old" V1 speedo as I have a better feeling with this one.
V2 is more smooth on power but lacks power midrange and topspeed.
When I tested V2 I ran with 4.5T feeling 5 and boost/timing 8 to get good power. With V1 I use power program 6 and I have more power.
I don't know the differents in shock oil between the two. The reason all TRF use Much More is that we have always the same reference.
See you at next TITC!!
- Oliver
Non of the TRF drivers has had the 417 yet, hopefully I receive it very soon.
All things that could have been betered on the 416X are now done in the 417!
We have tested already with bigger pullies and this makes a big differents, more smooth drivetrain and also the feeling of the car is better, don't ask me why this is.
If you want the 416X now and you want to upgrade to 417 you need:
-chassis
-topdeck
-motormount
-pulli ( I think also different belts)
-steering system
So it's up to you!
- teamsanwa
See answer Jonest
Jilles
Old 09-20-2010, 08:32 AM   #1289
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Originally Posted by JGH View Post
Hello racers,
- xray009Act
jilles: hey, no mentioning names! hahaha .... hey, is it true the titc next year is all booked? thats what the site says. i hope not because we're really planning to go .... http://www.titc.in.th/ or is that referring to last year's race? i hope so!
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 09-20-2010, 09:48 AM   #1290
Drew Ellis's Avatar
Whats up Jilles. Just stopping by to say hi. Hope things are well.
Thanks Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
