Old 09-01-2010, 04:47 AM   #1261
marcel p's Avatar
Send a message via MSN to marcel p
dont use tyre warmers on carpet.
make shure the tyres ar glued realy good.
treat the rear tyre full 30 min min with carped tyre smear
front inner half for 30 min.
should work great
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 09-01-2010, 05:17 AM   #1262
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Pinion King View Post
Hi Jilles,
Being driven absolutely nuts by an issue I am having with my 416X. At the start of the race, the car is great, as the race goes on, the car gets worse and worse.
Turn a corner and the rear of the car steps out, and the car really starts to oversteer heavily, and at times traction roll. It costs me up to 1/2 a second a lap as i have to back off to get thru corners and widen my apexes to keep the car as straight and stable as I can.
It had me confused, as a few days before at a weekend event (we race on Wednesday nights, indoors) the car was great, and I hadn't adjusted it between the weekend and Wednesday.
I have tried many different setup ideas and nothing is solving the problem. Out of curiosity i measured my tyre temps when i pulled the car off the track. The fronts were 10deg (c) warmer then the rears, i checked and my dad was also having the same issue. His rear tyres were also cooler then his fronts.
We race on carpet so we use tyre warmers before the race. It seems to be that as the rear tyres cool they are loosing their grip and the fronts are taking over. Which makes sense as to why the car was so good during the weekend event, it was warmer conditions and tyre temps stayed even.
How can I get around this? Is there a way to keep more heat in the rear tyres so it doesn't go off so damn much.
Also took notice that my front tyres wear a lot fast then my rears do.
It is normal for your front tyres to wear more than your rears. The issue could be your tyres overheating. Normally when that happens your car gets both loose and understeery at the same time, but the looseness is what catches you out.
The easiest way to find out what's going on is to stiffen up the springs. If your car gets worse quicker than your tyres are overheating.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-01-2010, 10:08 PM   #1263
JGH
Hello guys,
My apoligizes for not being around on the thread lately.
Attached my Worlds set-up.
Later today I will answer all other questions!
Jilles
JGH is offline   Reply With Quote
Old 09-01-2010, 10:48 PM   #1264
transplantlife's Avatar
Trader Rating: 43 (98%+)
Jilles~
Wanted to get your advice on the new lipo chassis for carpet set up. Would you suggest that i start with your LRP Masters set up or SNOWBIRD set up.. Thanx for the help.
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 09-04-2010, 10:59 AM   #1265
Hi Jilles,
Nice that you will help other TRF drivers, we appreciate this!
here are my questions:
- what big setup changes do you make when it's raining?
-i saw you're basic outdoor setup, does it works for stock racing with a 10,5?
or do i have to change the camber angle, sus mount, ec.. ?
Thank you so much
TamiyaRC is offline   Reply With Quote
Old 09-09-2010, 11:16 PM   #1266
CHRIS CHAVEZ's Avatar
Hello Jilles,
I'm in the market for a new servo. Could you please tell me which servo manufacture and model number you were using at Snowbirds and at the Worlds?
Thank you, Chris
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 09-11-2010, 02:34 AM   #1267
bump
TQ RC Racing
Old 09-11-2010, 05:37 AM   #1268
Senna Racing's Avatar
this question has been answered before
try the search function
Good to see that your back on here Jilles we have all missed you ( well i have ) and look forward to your insight
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 09-11-2010, 07:09 PM   #1269
Questions?? WHICH WHITE SPRINGS?
I am really confused. I bought a set of Tamiya TRF shocks part 42102 - they come with a set of Tamiya white springs - which happen to work great on my car. (sadly not a 416 )
My question is this. What is the part number of this spring? I ask this because I checked out the petit rc touring car spring chart and that contains three different Tamiya White springs.
help me please
Lohan is offline   Reply With Quote
Old 09-11-2010, 08:21 PM   #1270
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
help me please
The white is always a bit misleading, but each of the TRF white ones should have a small dab of coloured paint on one end (eg blue or yellow). It's the colour of this small bit of paint that tells you how stiff the spring is. Not always easy to see, particularly after a few races.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 09-12-2010, 12:15 AM   #1271
I already tried that but thanks for your help.
TQ RC Racing
Old 09-12-2010, 06:34 AM   #1272
AHHHHHH!
they have a yellow dot!
thanks
Old 09-12-2010, 06:41 AM   #1273
Questions?? which yellow?????????????????
I feel like an imbecile.
Springs are white, and have a yellow dot on them. They came with TRF shocks that are blue in colour.
the problem I have is that there are about 3 or 4 different tamiya white springs
tamiya don't make it easy
Old 09-12-2010, 06:45 AM   #1274
barts71m's Avatar
Lohan...my TRFs came with the three sets of white springs, just checking now and they have a blue, yellow and white dot on them.
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 09-14-2010, 05:22 AM   #1275
CraigM's Avatar
The tamiya shocks come with 4 x tamiya yellow springs (white springs with yellow dots).
