Old 07-20-2010, 12:04 AM   #1231
Suspended
Trader Rating: 17 (90%+)
Jilles,
Would you say that the majority of top tiered TC guys run similar drag brake settings? Or is it more of a personal preference?
And what do you run and why?
StickyFingaz is offline   Reply With Quote
Old 07-20-2010, 06:41 AM   #1232
Andy63's Avatar
do you always brake with the drag brake or do you also use the brake on the radio? and please tell how you use it. thanks!
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 07-20-2010, 10:18 AM   #1233
Send a message via MSN to jontang001
Master Jilles
Thanks for the answer!
I still have some following questions....
I went to see those previous pages in this topic about carpet settings information.
I saw an answer that you said: [For indoor we always use 1 o-ring, the blue Tamiya one with little bit of rebound, 5mm.]
According this answer and the answer you given me yesterday...
1. Does 20% rebound equal to 5mm remainder that you push in the shock pin?
2. Will you drill hole on the top cap of shock on carpet track?
3. The o-ring is on the blander or just in the bottom of the shock?
4. I follow your advise to see your setting at 2010 LRP Masters, why you use 2 o-rings?
I really didn't had much experience on carpet race...
Thanks for your help and patient!!!!
Jon
TAMIYA TRF416, EVO5MS, TB03 FullOP
Schumacher Mi4LP, CAT SXII, Cougar
jontang001 is offline   Reply With Quote
Old 07-20-2010, 11:02 AM   #1234
hi Jilles,
I love to get a trf416x soon. This thread really help a lot. Though the price for a trf416x is really out of reach for some (like myself), but I'm sure this is really a nice piece of machine. Still saving hard
Keep going buddy!!! Good luck on your upcoming races.
p.s. trf416x is really expensive. got an unused chassis?? maybe you can donate to me .Cheers!
hansenhon is offline   Reply With Quote
Old 07-21-2010, 07:00 AM   #1235
Hi Jilles, what does "3mm o-ring" in the setting sheets mean? Is it an o-ring in the shock bladder or shock shaft to limit length? For example in your TITC Mini it says 1pc 3mm o-ring.
Thanks in advance.
Joel
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 07-23-2010, 06:29 PM   #1236
Hi Jilles,
Would you please share some experience of sweep rubber tire on carpet? For example, recommended tire tweak, how to prep the tire before running, thanks.
srw_g is offline   Reply With Quote
Old 07-24-2010, 05:51 PM   #1237
team minkya trf's Avatar
hi jilles
how could i prevent understeer
speedpassion|trf416we|protoform|lrp|sanwa|m03|f109|hitec|xrayt2|tekin rs
team minkya trf is offline   Reply With Quote
Old 07-27-2010, 03:35 AM   #1238
Does anyone have a link to Jilles 416x asphalt starting setup.
Cheers
Smartypants is offline   Reply With Quote
Old 07-27-2010, 04:25 AM   #1239
try here:
http://www.petitrc.com/reglages/tami...miyaTRF416.htm
or here:
http://www.thard.co.uk/viewforum.php?f=30
jorgesimes is offline   Reply With Quote
Old 07-27-2010, 09:37 AM   #1240
xdunebuggy's Avatar
Default TRF 416 oversteering
Hi Jilles,
my brother and me got the same problem with our 416 WEs.After half a year understeering like normal 416s do,from one to another run we got very hard oversteering.no new tires,changing shock positions,or changing the suspension mount helped.we still run the standart setup.
whats wrong with our cars?
Tamiya-Hotshot,Bigwig,Frog,Brat,M.Pumpkin,Boomerang,TRF415,-MSX,-MSX MRE,416 WE-XL,Atomic VM-II
Barracuda R2,Losi XX-4WE,Mini-T
xdunebuggy is offline   Reply With Quote
Old 07-27-2010, 09:44 AM   #1241
jonest's Avatar
Originally Posted by xdunebuggy View Post
Hi Jilles,
Check ur ball diff.... I'm having this problem too. And the car was pretty hard to drive.
jonest is offline   Reply With Quote
Old 07-27-2010, 05:35 PM   #1242
JGH
- Stickyfingaz
Dragbrake is a personal preference.
On my Tamiya/LRP speedo I use normally program 3.
I'm sure all topdrivers use a small amount of dragbrake.
- Andy63
I always use a little dragbrake + I use also brake on my radio.
Every corner is different so you can't set only your dragbrake.
- Jon
1. Little rebound is about 50% but the shaft goes very slowly up.
2. I normally use standard top cap for carpet and drill hole for asphalt.
3. I never use anything on top of the bladder.
4. At LRP race I test 2 o-ring in practise and it gave a little more dampening = traction
- Hansonhon
Thanks! I can't help you with a second hand 416 but i'm sure you will find it.
-Joel
In the mini I used an o-ring inside the shock to make the shockshaft shorter, less droop.
-srw_g
I not ran much with the sweep tyres but normally tyre tweak or FX2 works best on this tyre.
-Teamminkya trf
Please share a little bit more info.
-xdunebuggy
This question I cant answer as I don't have much info about tyres, track conditions etc. Please share more detail.
Jilles
JGH is offline   Reply With Quote
Old 07-27-2010, 06:20 PM   #1243
CraigM's Avatar
Trader Rating: 34 (100%+)
Good luck in Houston Jilles! looks like you are going ok already, hopefully the weather improves
When you are finished playing with the gas cars can you please share your setups from MACH ETS and the Worlds?
Craig
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-28-2010, 07:02 AM   #1244
xdunebuggy's Avatar
Default Oversteer
We drove the ball diff first-now spec-r with mugen 2000 diffoil ,no difference!!!
Old 07-28-2010, 09:12 AM   #1245
Hi, Jilles
About front suspension blocks. What's difference between C/C and B/D? What's rule to choose them in different condition? Thank you.
